OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
My understanding is that the heat wraps keep the temps up in the turbo, muffler, etc. and this keeps the flow velocity up. They can also keep underhood tempps down. The downside is that wraps can be hard on parts, with corrosion, ruct, etc.
Just my .02
Originally Posted by bkreigsr View Post
I'm of the opinion (I could be wrong) that any kind of wrap or foil will only increase the exhaust temp by keeping all the heat in, and decrease the efficiency of the turbo. - especially if you have no intercooler, like NO RSR.
Bill K
Old 07-17-2010, 05:51 PM
cycling has-been
bkreigsr's Avatar
to qualify the the 40 deg temp reduction statement: - at Watkins Glen with the ambient temp 80-90 degrees, the oil temp gauge was reading between 250-260 degrees after 8-9 laps in the red group. After the bumper mods, temps for the same situation went no higher than 220 degrees.
I put the fan in solely for stop-and-go traffic where I had seen over 300 degrees on several ocasions. The fan keeps temps down below 250 in the same situation and helps reduce the temp faster once traffic lightens up.
Bill K
Originally Posted by hoyabear View Post
Bill,
Interesting to see that all of those slots have reduced oil temps as much as 40 deg! I like the look of the stock rear, but I am definitely considering going towards some kind of slotted/vented bumper now.
I'm installing a fan on the carrera cooler this weekend (hopefully), we'll see how much that helps with the temps on my car (runs really hot ~ 250+ on a hot day), I might have to start poking holes!
Old 07-19-2010, 05:47 AM
surfpangea
Sam Matthews's Avatar
I can not believe you cut those by hand if tried that it would look like Frankenstein very clean job.
I would reinstall the seal as it keeps the heat from the bottom (turbo and headers) from cycling into the top (intake) of the motor creating overheating. Just a thought
Old 07-31-2010, 03:26 AM
Certified User
billjam's Avatar
Sam,
I think you are confusing the seal around the engine tin with the bumper-to-body seal.
The engine tin seal keeps the heat out of the engine bay - which is a good thing! (I just fitted a new one.)
The seal between top of bumper and body is more cosmetic than anything else. It also only stops air from escaping from the area around the turbo and muffler - which is a bad thing This is the one I removed.
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 07-31-2010, 05:04 AM
