Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
race911turbo's Avatar
930 twin turbo
With 2 Garrett/Tial GT-35R turbocharger. while doing the conversion rust in my fuel tank kill both of my fuel pump...made a aluminum fuel tank with Aeromotive fuel pump.....
1975 914, 1988 944 turbo S sold.
1986 944 turbo resleeve 2.7, DTA S-60 PRO.
1986 911 Carrera with 965 turbo motor, DTA S-80 PRO.
1989 930 EFI, DTA, Carrera intake, twinturbo,2x GT-35R.
1991 964 convertible, wide body conversion.
Old 07-24-2010, 01:46 AM
R.I.P.
drmatera's Avatar
wow, twin GT35's. Big power potential there
Old 07-24-2010, 05:43 AM
Blackbird Pilot
Reaper930's Avatar
Nice! Info on the IC?
Are you doing anything to get air to the turbos or do they just suck from the engine bay?
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 07-24-2010, 06:16 AM
Crotchety Old Bastard
RarlyL8's Avatar
That's pretty cool, I make a similar setup. Those turbos are huge, how is this car used and what is the output?
Old 07-24-2010, 06:32 AM
Very nice work and very extreme!
May I ask, what is the strategy with two 35's?
Basically that is like one GT-35 on a 1.7 liter motor. Can that drive a GT-35? Where should boost come in?
The best.
Old 07-24-2010, 08:37 AM
930gt-40r's Avatar
2 35Rs? Now thats how you make some power! Sweet- did you us the .63 v-band housings?
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 07-24-2010, 08:44 AM
wcc wcc is offline
wcc's Avatar
Looks like the GFS setup..
930-twin-turbos
Bill
Old 07-24-2010, 09:02 AM
RarlyL8's Avatar
Yes GSF, Albert is that yours? Thought you lived in China now.
Old 07-24-2010, 10:32 AM
Looks good!
How does it run?
How do you equalize the two banks boost?
What about some numbers...?
Thanks!
Old 07-24-2010, 03:23 PM
Brian, Yes I am in Taiwan, Yes I am from GSF. The reason I move to Taiwan my wife is a TV entertainer/ actress in TV series and movie....
I have 2x Tial GT35 R turbocharger ( it is for single 930 turbo spec) with me, I was making 6 ITB with twin turbo setup. The machine shop and I didn't agree with linkage setup, we stop the 6 ITB twinturbo setup..........
I already took all the intake and exhaust parts out of engine and I have all the parts in the shop so I put them together....
One nice thing about Tial GT-35 turbine housing they share same flange with GT-28R and GT-30R.
I can switch to smaller turbocharger within 2 hours...
The aluminum fuel tank cap isn't back from machine shop, for now I can only move the car around not test drive the car......
At idle I can heard the turbocharger spinning....Thanks to Tial turbine housing, It makes turbocharger spinning earlier...
Old 07-25-2010, 06:44 PM
tj930's Avatar
Amazing!
What sort of numbers are you expecting? (BHP, 0-60mph, 0-100mph, 60-150mph?)
Old 07-26-2010, 01:52 AM
The Aeromotive fuel pump, AN-10 fuel hose, turbochargers, 83 lbs fuel injectors are good for 1000 HP, 6 ITB, GT-2 cam, 41 mm intake port equal length turbo header, water injection. in a 3.4 - 3.8 L motor red line at 8000 RPM....... 800 HP would be a good number.
Old 07-26-2010, 06:46 AM
935TURBO's Avatar
Yes.....why not....considering this.....only 3.2 L and no EFI.....
Porsche 935/78 « Moby Dick » Chassis 935.81.JR.001
Engine: Six-cylinder, two-valve, air-cooled opposed-piston, twin turbo engine
Output: over 800 HP at 8200 RPM
Displacement: 3211 cc
Fuel system: Bosch mechanical injection pump, 120 liter fuel tank
Driveline: Four-speed gearbox, no differential
Chassis: Light-metal, tubular space frame, plastic body, independent suspension, coil springs, vented disc brakes
Wheelbase: 2279 mm
Length: 4890 mm
Weight: 1025 kg (by rule)
Performance: Top speed 365 km/h
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 07-26-2010, 07:15 AM
esotoracing's Avatar
Any updates ?
theres nothing like the rear end squatdown of a turbo
Old 08-16-2010, 12:27 PM
off subject, but is that a bendpak scissor mid-rise lift in the first pic?
John- I blame and thank the longhood boys of Austin
-84 911 Carrera w/ 930 t/p,efi'd,dizzy free,HFS turbo, 78 930 RoW no option sunroof coupe, 64 Corvette roadster, 71 911T, 73 911E, 67 Bronco survivor. 71 FJ40, 95 M3 (for sale)
"Illegitimi non carborundum"
Old 08-16-2010, 12:50 PM
Banned
Albert, are these .82 a/r housings??cheers.
Old 08-16-2010, 03:55 PM
Yes, I have 2 Tial GT-35R turbocharger with .82 AR ratio in stock so I put them on... at idle it spins pretty good........
Old 08-16-2010, 06:04 PM
Have you Dynod yet ??
Old 08-16-2010, 07:57 PM
No, I have not dyno yet..
Old 08-18-2010, 03:42 PM
