LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Crotchety Old Bastard
RarlyL8's Avatar
There is another option, but it also has a draw-back. One of the sound options for my systems is the Outlaw, a straight pipe. It replaces the muffler body in the system you have now. The 5" diameter muffler becomes a 3" diameter pipe.
The draw-back of course is noise level.
Old 05-12-2011, 07:47 PM
proffighter's Avatar
Originally Posted by kas930 View Post
Roland,
More or less I went thru all of the same struggles that you are going thru. Although the muffler that I had before my conversion still fit, I was going for the IROC look and wanted the exhaust to come straight out the back. I had the same fitment issues with my rear bumber which was purchase from GT racing. From point to point, it lined up perfect, but just like your seeing the contour wasn't the same. I cut and re-glassed it to get it right. Good luck.
Keith
This seems to be the way to go, except I find a bumper thats more set back (and its's not too pricey)
To reduce the amount of work I could cut like this:
Roland
930 Turbo '81 Too many modifications to list
Old 05-12-2011, 10:30 PM
Brian, this would be the very easiest way, but I will be shoot immediately as soon I left the garage, simply too loud. Remember, the present muffler sounds very good, even it's at the limit for road-use here in Switzerland (and illegal anyway )
When I look from back to the car, I can see the muffler is not exactly horizontal, It slightly decreases to the right, not your issue, has to do with my turbo position and also the right end is more back then the inlet side vice versa to the stock. Here it would be nice to have another clamp right after the turbo to compensate the misalignment by turning the muffler (maybe an option for the future, what do you think?)
Roland
Old 05-12-2011, 10:36 PM
RarlyL8's Avatar
Yes noise is an issue but I thought I'd throw it out there as some folks like the volume.
I've thought about that many times but hesitate to add another slip joint and clamp as it begins to look too cluttered with clamps. What you might do is tighten the top bolts first and then the bottom. The muffler body will angle up more while remaining sealed by the gasket.
Old 05-13-2011, 05:51 AM
Because the bumper is useless anyway, I decided to cut in pieces and see, if It can be machted with modest effort and extend in length and wide:
Roland
Old 05-16-2011, 01:00 PM
valance/iroc
I had to cut the valance, to clear my B&B muffler. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 05-16-2011, 02:09 PM
after parting the bumper in four pieces, I put them together, each on its wished position fixed glueing wood sticks (aligned on the car of course)
Mounted to check the fit, not bad. Now I can smoothen out the corners and after fill the gaps. I also checked the cut-out for muffler, still to small, but good to get an idea, how much more to cut away
Roland
Old 06-02-2011, 01:53 PM
After a weekend spending hours for laminating and grinding I am finished with adapting and checked fit befor painting, not bad finally
Roland
Old 06-08-2011, 03:07 PM
bumper litz
Hello roland, Its looks like you are handy with fiber glass. Nice Job! Have a look at my bumper in post 26. I have bumper litz above my plate, installed in the frame. They give the bumper a nice clean/smooth look. They are LED, and do a good job. These lights are only $20 cdn. on ebay. I bought a few different styles of lights, but none did a nice clean job as these. Hope this may help. cheers from Canada. Philip
Old 06-08-2011, 03:44 PM
After a few weeks since my last post, I am now finished with the bumper.
Here it is after cutting and rebuilding the contours at the flares.
Further I extend the area under the reflector for mounting there
After checking fit on the car, I back-chiped (correct word?) the connection areas and add a few layers from outside. The reason is to get better strenght and avoid mark-ups at the seams
Roland
Old 06-28-2011, 12:29 PM
After one week at the painter, here is the final result
The extension of the bumper is 20mm backwards, which gives a better lock and most important, more room for the RarlyL8 muffler
Roland
Old 06-28-2011, 12:36 PM
Nice job and it looks like you found some German fiberglass like Porsche used for the top layer.
I havn't seen that nice fiberglass cloth weave since I worked at a porsche racecar restoration facility back in the mid eightees.
You also have a layer of kevlar/carbonfiber cloth and a small layer of carbonfiber cloth in your composite layup.
They would often use a strip of carbon fiber cloth sandwiched in with the glass for more strength at the edges where bodywork came together.
Old 06-28-2011, 01:45 PM
Well, I used epoxy system L instead of somehow polyester. Glass is a very common type, easy to drape
I buy my fiberglass stuff here: suter swiss composite group
They have a very good PDF for downloading to get an overview to the theme. Very huge amount of products, helpful people there. They also sell a lot of aero certified stuff. Mine is same quality, just no certifications and thus cheaper
The carbon and kevlar layers are for more strength in that area, because I made the bumper attached to the chassis there
Roland
Old 06-28-2011, 02:33 PM
RarlyL8's Avatar
Nice!
Old 06-29-2011, 07:32 AM
Scottsdale Arizona USA
Well executed composite work Roland. I notice this one has the full license plate recess which seemed to simplify the curve. The licence plate lights are cool. Are those Hella or anything special? Also the original bumper you had was made by who?
EP-West // Automotive Part Connectors & MODE : Motorsport Design
1 (844) URO-PART // day@europartswest.com // mode@europartswest.com
Old 06-29-2011, 09:03 PM
Brian
Thanks. The lights are from a Raco dumper, which is made by the company I work. Don't think they are available in the US. I will check the brand tonight...
The original bumper? If you mean the at the beginning of the thread, this was from Betterbodiesmotorsport, some kind of Strosek copy. If you mean the one I adapt now, it's made by: MRS-DESIGN-SHOP
Roland
Old 06-30-2011, 01:52 AM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
Nice work!
Taze em..TAZE EM ALL!!
A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker.
It looks like the 4th of July from my rear view, how about from your view?
Old 07-05-2011, 06:29 PM
Profighter, I love the shade of blue.
Blues my favorite color, Keith, nice work on your red machine.
Old 07-05-2011, 06:32 PM
