bruni911's Avatar
Best tranny oil for g50/50
Hi i was going to put in sweepco 201, but someone said thats its no good for the g50/50 tranny only for 915?
What should i use?
Old 08-02-2010, 07:27 PM
Banned
Here is a long thread on trans oils . . .
Swepco Transmission Fluid Question
Old 08-03-2010, 10:13 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Arrow and around the bouy we go...
... one more time
Who Will Live... Will See
Old 08-03-2010, 10:25 AM
swepco is not correct for g50 read this
Mobil Delvac 1 trans fluid?
Old 08-03-2010, 11:53 AM
Metal Guru
911nut's Avatar
Lots of 964 guys on Rennlist swear by Delvac but it doesn't work very well in the G50/52 with limited slip.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 08-03-2010, 04:07 PM
Manassas, VA
lucittm's Avatar
Paul,
I know you mentioned this about Delvac before but could you elaborate a bit. Is it a certain feeling you get in your car or is it a repeatable test process to exercise the LSD? I put the Mobil-1 Delvac in mine and I noticed no difference. Maybe I had Delvac in there from the PO, I don't know. But I would be willing to find out how to tell if my LSD is working the way it should, or not.
I admit to knowing how to spell LSD (and know that it means Limited Slip Differential).
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 08-03-2010, 04:43 PM
I used...
Valvoline 75W-90 full synthetic in my 87 carrera, with G-50. no regrets, and available in Canada
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 08-03-2010, 04:44 PM
Metal Guru
911nut's Avatar
Originally Posted by lucittm View Post
Paul,
Mark, my diff was rebuilt about 6k miles ago by the PO so I'm assuming that the friction plates aren't worn out.
When I drove my car with Delvac, the diff felt like it was locked. Very little to no slippage at all accompanied by lots of ugly sounding noise right away.
I drove straight home and changed it to Mobil 1 LS. Problem solved.
In hindsight, I could have added slip agent to the Delvac.
When you corner you should hear the diff slipping on trailing throttle. If there's little to no noise I'd guess that the friction plates are worn.
Paul B.
'91 964 Turbo
Old 08-04-2010, 05:02 AM
tj930's Avatar
I just had a crunch into 4th gear last night, about 1/4 mile from my home (no, I wasn't drag racing).
What's everybody recommend for 4-speed 930 'box oil? (Used to be Swepco something or other; has the consensus changed?)
Old 08-04-2010, 08:04 AM
