Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
02fly's Avatar
short shifter
What's the best short shifter fo a street driven 4 speed turbo.
Thanks all, Don
Old 08-04-2010, 11:08 AM
gumba's Avatar
WEVO Welcome to Windrush Evolutions - WEVO - Porsche Products
Harold
'79 930/DP935
'68 VW Turbo Crewcab
Old 08-04-2010, 12:13 PM
Tinkering Pays!!
mooney265's Avatar
On this subject: Can I get a shifter that's positioned a little bit further 'back' and maybe a little higher - - maybe 3-4 inches? I already have the short-shift kit installed, but have a hard time staying seatbelted in and hitting 1st and 3rd [gotta lean forward too much]... Maybe my arms are just too short
Thanks,
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 08-04-2010, 02:00 PM
Alot of people would like that, and not only in 911's
I have a weltmeister short shift kit with tight bushings throughout in mine including the coupler.
I removed the leather boot and rubber boot under it and heated the steel shift rod red hot where it bends back with an acetylene and oxygen torch, then bent it back about 1 inch farther and over to the left around an inch.
That helped and I don't have to lean forward a little to shift into 3rd now.
Old 08-04-2010, 02:18 PM
Tinkering Pays!!
mooney265's Avatar
Pic with boots off?
Old 08-04-2010, 04:02 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I did the heat and bend on my short shifter as well. Worked ok, but not good enough for the track when belted in tight. The Hargett shifter pulls it up and back just right. It's just right there. No info on the WEVO, but hear good reviews.
Old 08-04-2010, 04:28 PM
Tinkering Pays!!
mooney265's Avatar
From the pics, the hargett looks like it does just that... just needed someone with 1st "hand" experience - thanks...
Old 08-04-2010, 04:31 PM
Originally Posted by mooney265 View Post
Pic with boots off?
I don't have any pics of it.
The lower part of the shift rod should be straight up when in nuetral. The upper part that is bent back can be wherever you like it.
Someone on the technical forum made an extension about 3" long for it. Maybe a search would find it.
After bending it you can remove it, then sand and respray paint it satin black.
Old 08-04-2010, 04:36 PM
Oh Haha's Avatar
I love my Hargett shifter
I don't have one in my SC but struggled with the same problem you are having reaching the shifter when belted in. I customized my shifter with bits from Weltmeister and the factory shoft shifter to my tastes.
Pacific Blue
Wayne
Old 08-04-2010, 04:48 PM
WEVO you will love it. I had the factory, weltmeister, and whatever AJ racing had. Wevo is by far the best.
Old 08-04-2010, 05:20 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
I modified my factory shifter years ago before my current setup. I have done this with 901's, 915's, 930's and G50's with the same results. I cut the section of the floor and move it back and straighten out the shift lever. after that The linkage rod needs to be cut. Although it doesn't shorten the throw, it does change the length of the shifter which in turn does slightly shorten the throw. But the placement makes up for it.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 08-04-2010, 07:53 PM
935TURBO's Avatar
I just got the WEVO from Dave, DDDD.......looks nice.....I'll put it on the car soon.....I'll post pictures of the works..... Back on the block.........935 TT & EFI project.......Which ECU....?
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 08-05-2010, 04:14 AM
