boost guage
Today while driving, I noticed the boost guage started staying at .2 driving not under boost, and idling at light. Turn off car and guage fall completly to 0. Car runs fine, and in the past the guage would stay at 0, till turbo started to spool. Did a search but cannot find anything that mentions this. Also this is the stock guage. thanks Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 08-05-2010, 06:23 PM
89 930.
Benny771's Avatar
My 89 does the same....... not saying it is suppoised to do this, just saying mine does as well.
Old 08-05-2010, 06:30 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
The stock gauge is worthless. If you want accuracy, get a NHS Speedo or similar boost gauge.
Old 08-05-2010, 06:44 PM
mark houghton's Avatar
You can always check the connections on the boost sensor/sender unit (engine bay, about 2" diameter, covered with an orange rubber thing) to make sure that's not your issue. Here are the basic resistance values to tell if the sender is working properly:
0.0 Bar 5 - 13 Ohms
0.9 Bar 117 - 129 Ohms
Of course you would have to take it off the car and put air pressure to it to see if the values are in line. Somewhere I have a complete mapping of resistance values for each psi pressure change.
I still have mine fully functional, in addition to an aftermarket gauge. Believe it or not, they're usually pretty close to each other. Maybe I'm one of the few lucky ones!
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 08-05-2010, 07:13 PM
