Hot start question.....
After driving my car, if I shut it off and then start it again after 15 or so minutes it has a miss. It's only for 5-10 seconds and then it clears up. I'm thinking it may be a leaky injector fouling out a plug? Any other ideas? It's a 79 3.3 with SC cams and euro CIS. Thanks.
Old 08-07-2010, 06:22 PM
mark houghton's Avatar
The symptoms would suggest that. Short of pulling all your injectors and flow testing them, you might want to start with pulling the plugs to look for any indication of rich mix. I would do that directly after you've experienced the symptoms, i.e., don't run her long enough for the engine to "clean up". Catch it at it's worse moment and see if you can find a wet plug...then go from there.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 08-07-2010, 06:30 PM
