Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930 conversions
This may be a remedial question but here goes. Can any one tell me if if it is possible to place the entire suspension and drive train from a 86 930 under a 74-75 911 chassis?
Old 08-07-2010, 08:30 PM
The rear suspention inner mounts are different so it is not a direct bolt up.
Old 08-08-2010, 05:59 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Yes, But as 911st stated, the rear suspension mounting ears on the torsion tube are raised slightly. Smart Racing sells the tabs to convert to the 930 arms. It is easy if you can weld or have access to a welding shop.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 08-08-2010, 06:30 AM
I would rather be driving
jpnovak's Avatar
The 930 trailing arms are also wider. You must also install flares to accommodate the extra width.
You asked about the entire suspension. The front suspension will bolt up to the chassis. If you are using pre-80 you will need to remove the hub spacer and change the brake hat. If you are using later front suspension you will need to change out the front hubs that have the offset built in.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 08-08-2010, 09:05 AM
Originally Posted by jpnovak View Post
The 930 trailing arms are also wider. You must also install flares to accommodate the extra width...
For what it is worth, yes the arms are wider at the wheel hubs and that is generally the case but dose not have to be. One can remove the spacers and use wheels with corrected offset. Again, 930 arms have been used with SC/RS flairs but it is rare to do so.
Old 08-08-2010, 02:30 PM
DP935 member
kycarguy 935's Avatar
I have done it 3-4 times in the last 22 years. The toughest part of the job is to install the rear 930 torsion tube and get it lined up correctly.
I think it is more economical now to buy a 930 and sell the 74.
Average prices for a complete turbo suspension is $4-5k
...engine $6k plus
...trans.$2k plus
...flares $800-1,000
plus labor.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 08-08-2010, 05:12 PM
...engine $6k plus
...trans.$2k plus
plus labor.
do you mean the torsion bar(s) or does the torsion tube from the 930 have to cut out of the 930 and then welded into the 74 chassis?
Old 08-08-2010, 08:55 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
You can cut the center section of the 930 "torsion tube" and cut the 74 "torsion tube" out at the same width and reweld the 930 center section in place.
Or
Buy these from smart racing which would be less work
911 Rear Control Arm Pivot Box
Upgrade Kits (Using 930 Arms)
Part No. 562020
Questions or comments please call 408.369.9997 or FAX 408.369.9741
Smart Racing Products - Home of SmartStrings, SmartCamber, and other quality performance auto parts
Overview:
The idea is to allow non-turbo cars to be upgraded to use of turbo arms whose pivot has
been moved up and back. This reduces acceleration squat tendencies and makes the
camber curve characteristics of wider wheels and tires more effective; also allowing a
more simplified camber adjustment method. Bump steer curves are more ideal as well.
These boxes are also available for standard 911 control arms (part #4001-911).
Camber will now be adjusted by raising and lowering the center pivot bolt. This will not
affect the toe settings (no more crawling under the car to change camber angles and then
readjust toe!) You adjust camber from the inside of the car with 19 and 22mm wrenches.
Simple self-aligning and self-fixturing. Note that modification to the back seat area for
clearance of these boxes will be necessary.
Old 08-08-2010, 09:48 PM
Or
Part No. 562020
Overview:
Thanks for the link. You would not happen to have any pics of the conversions you have done in the past would you? Aslo, will there be any problems with the engine and tranny installation? Thanks for your time
Old 08-09-2010, 07:57 AM
Scottsdale Arizona USA
I had a 74 chassis with this done to 89 flatnose spec. Accommodation for the longer G50 type gearbox is worth it! The 74 chassis is considerably lighter. Adding the proper torsion tube section and reinforcing the chassis is recommended. Check out this 74 project car for reference if you like. It recently sold to a nice guy who got the concept in Florida.
Porsche 930 Flatnose : For Private Sale
EP West // Automotive Part Connectors & Motorsport Design
1 (844) URO-PART | day@europartswest.com
Old 08-09-2010, 10:24 AM
