Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
There are a lot of 930's where the motor was toast with well under 50k miles and examples of those going 200k on the original long block.
Moded saves money but to me adds somewhat to the question to condition. However, even a stock 930 you will never know if the owner had jacked the boost, added to the wear, or cracked a ring.
I lean toward getting one with the mods I want. At a minimum a good intercooler as they can be expensive and are getting harder to find. One from Andial like above, Koklen, or one from a stock 91-94 911 Turbo. If you are going to track it, the stock suspension is to much fun and should be addressed. Even a low mileage 930's suspension bushings are probably in need of replacement just from time as they sag and this can damage the torsion bars from rubbing. Doing bushings, torsion bars, alignment and corner balancing can be several thousand dollars.
Basically buy the best condition 930 you can find. It if has a fresh motor from a respected builder that is a bit plus.
One specific. If it dose not have Carrera chain tensions, install them. You might be more lucky than I but I lost one 930 motor because I did not have them.
Lastly, it is probably a great time to buy a 930. There are some good ones to be had and I suspect when the economy firms up they could see the appreciation that the long hood 911's have.
Old 08-15-2010, 07:54 AM
Crotchety Old Bastard
RarlyL8's Avatar
If memory serves the blue car has been sitting for years and needs attention. Check that out.
Everyone's taste is different and most wish to make a car their own. Buying a modded car is only an advantage if it is close to what you would do if you started from scratch. The silver car has mods I like, but that is just me.
I have helped with modifications for several folks who had bone stock 930s. I like that you can remove the stock equipment and box it up. This preserves the resale value and gives you options once you decide to sell. One such car was a low mile concourse condition factory slant. The owner can now enjoy the car his way without fear of depreciating value. Just a consideration ...
Old 08-15-2010, 08:10 AM
