Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Driver
Noah930's Avatar
What's This?
What's this empty relay socket for in the left (driver's side) sidewall of the engine bay? (center of the picture, by the #51)
And how about this plugged bung on the right side of the factory intercooler?
1987 Venetian Blue (really looks like grey) 930 Coupe
Old 08-09-2010, 10:03 PM
nreed's Avatar
I believe it is a test port for the oxygen sensor system.
Norm '86 930
DTA P8Pro ECU - Synapse BOV - 60# Siemens inj - K27HF - Dual GHL - Kokeln IC - Elgin SC330 cams -
HRE 560R 8.5x18 ET25 11x18 ET0
https://flic.kr/p/nVgoAC
Old 08-10-2010, 06:52 AM
The thing that looks alot like a vertical round relay socket is for checking the lambda system pulse valve/frequency valve duty cycle.
Your ignition delay relay mounting screw is missing and it's leaning over.
Not a problem unless it's aluminum cover likes to be grounded or if the plug on the bottom comes off or one of the relays terminals on the bottom touches the edge of the rectangular hole cut in the aluminum relay panel shorting it out.
The plugged hose connection on the intercooler was for some of the early cars that had a second golden saucer valve similar to the deceleration valve mounted behind the warm up regulator, but with no small intake manifold vacuum line to operate it.
It was called an auxilliary air valve or something but had nothing to do with raising idle speed during cold starts... I've heard so many different names for the thing I don't care they're called anymore.
Later cars did not have one so the rubber cap was put on the intercooler hose connection.
Old 08-10-2010, 09:06 AM
Driver
Noah930's Avatar
Thanks for the education.
Interestingly the missing screw was sitting on the little shelf just under the lambda testing socket. I had the stock black plastic cover over this whole area so I have no idea how long the relay's been listing over like that. But after a 150-mile canyon run on Saturday and an autoX on Sunday, I can't believe the screw was just sitting there, waiting for me to put it back in place.
Old 08-11-2010, 01:27 AM
Not enough Gs... May be you need to go a little faster... :-)
Old 08-13-2010, 04:34 PM
