Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Wastegate?? 930 3,3 -78
Hello. when I blow air oo-o.5 bar in the control line on the wastegate blows air out of vent pipes. must it? or is my Waste Gate Diaphragm leaking?
Sincerely, john
Old 08-14-2010, 08:24 AM
Happiest when Tinkering
gsmith660's Avatar
leaking
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 08-14-2010, 08:53 AM
Hello. I have now separated wastegate and have doubts about washers di / sims should be there. or they have been retrofitted?
Regards john
Old 08-14-2010, 11:22 AM
gsmith660's Avatar
Shims need to be there so spring doesn't wear into aluminum.
Old 08-14-2010, 11:28 AM
Thanks for a great help.
john
Old 08-14-2010, 11:37 AM
gsmith660's Avatar
Your welcome
Old 08-14-2010, 12:04 PM
If it leaks constantly or doesn't hold pressure, you're right = leaking. And that is most probably what it is.
But, if it holds pressure, even at a low level, and then discharges it could be a worn out spring.
So, when rebuilding the diaphram get a new spring JIC.
Old 08-14-2010, 01:26 PM
Hello again. just one last question. the veil / sloop in the shaft / bushing, how much needs to be and should I lubricate it with copper grease
Regards john
Old 08-14-2010, 11:59 PM
gsmith660's Avatar
I am not sure but it should be along the lines of if you can feel it then there is too much slop, I would take it to a machine shop and check the runout and then press in a new guide and ream/fit it.
Old 08-15-2010, 04:05 AM
