930 oil/smoke issue
would anyone have any suggestions on an recent issue that has surfaced with while turning after the car had heat cycled seems to produced a large amount of smoke out the drivers side exhaust ? btw(twin outlet muffler). in a straight line all is well,no smoke but after setting at a light then turning.....oh boy. oil level is within normal limits. temps are about 150-175f. i did take off the i/c as well the intake pipe etc. and found about 10-15ml leak out of the i/c. i also looked down into the turbo housing and found pooling of oil about 2 " deep. my mechanic seemed to think it could be turbo seals gone bad that may allow the blow-by and therefore the excess pooling and smoking. as well checked the oil scavenge pump and it was fuctioning fine. any help or suggestions would be appreciated. p.s engine also has headers,k-27, after market drip tank with associated oil lines. just finished 1200mile break-in period when this arose. currently adjusting the valves. regards ,george
just rebuilt my turbo and thats all it was for me...as a rule however do a leak down while the turbo is being rebuilt
SpooledEuro - 2011 Cayenne Turbo Blk/Blk 1986 Turbo Coupe GP White/Pearl 1986 Euro Coupe Graphite Metallic/Blk 1973.5 T/E Targa Sephia Br/Tan 1969 T Targa Signal Orange/Blk |
Wow! Seven minutes after your first post, you rebuilt your turbo and fixed the problem! You are the man!
???? a little confused here...I did't create this post
SpooledEuro - 2011 Cayenne Turbo Blk/Blk 1986 Turbo Coupe GP White/Pearl 1986 Euro Coupe Graphite Metallic/Blk 1973.5 T/E Targa Sephia Br/Tan 1969 T Targa Signal Orange/Blk Last edited by Spooledeuro; 08-21-2010 at 08:59 PM.. Reason: Wow! Seven minutes after your first post, you rebuilt your turbo and fixed the problem! You are the man! |
Sorry spooled. I'm on my iPhone and thought you posted twice...
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Forced Induction Junkie
If you are experiencing this problem because you also have a new/rebuilt K-27, you might want to read Post #106 in this thread: Smokey exhaust
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Try a check valve in the scavenge line just on the turbo side of the pump. I just went through this.
kudos
thanks to all for the great research and advice. as always a great group and huge knowledge banks. my k-27 will be in the shop weds. for repair/investigation. fingers are crossed. regards,george
