poorly fitting fg bumper, any ideas?
Rear bumper, bought used here on the board, never mounted and I think I see why. Terrible fit at the back, easily an inch of space beloew the light panel and the flares are way off. Seriously, who actually manufactures something like this and sells it as a part that fits? ( I do have some ideas, if I remember one of those places that wouldn't accept credit cards for our own consumer safety...) This is not even close... Any ideas? I really like the look of the shorter tail, anyone have any pics of this one finished? Thinking of carving up a 965 bumper and doing a little graft surgery to make up the gap.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud Last edited by slyguy; 09-02-2010 at 07:24 PM.. |
Better bodies. Of course.
You don't like mexican horsehair plaster crapola? Tough. They only accept cash and have no return policy. So reselling it seems like the trick apparently. |
Happiest when Tinkering
The gap under the tail lights could be closed up using part of the stock 74-84 seal I think and as for the big gap under the reflector might be a good deal to vent some of that hot air from around the turbo you could fab up some expanded metal to make a grill that fits that hole as for the flares well that is just part of fitting FG parts they are never perfect unless you get some really high end parts. The old saying is "If you bodywork them they will fit."
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Or I have also seen 1 inch closed cell foam used to close up gaps.
Yeah some work to be expected but this is pretty bad. I'll likely eliminate the seal as they always seem to come undone anyways, it would just be hanging in the middle section. The foam intrigues me, although I still need to securely fasten the bumper somewhere in the back by the reflector which brings us to the original fit isseu. Just cut up some cardboard templates, the 965 bumper is going under the knife...
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud |
According to this installation video, there needs to be fabbed some bolts that goes under the rear deflector.
YouTube - Porsche BBMD 930 turbo rear bumper install
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Along with that video I would fab a heat shield to go between the turbo hot parts and the fiberglass or your paint won't last long I would think. I would still put some closed cell foam between the bumper cover and the tail light housing and the stock rubber welting between the flares and the bumper to keep your fiberglass from grinding away to nothing from vibration.
![]() Tom
OFF THE BOOST PIPE NOW...
I'm pretty sure Hanz and Franz back at Porsche install the rear bumpers the same way...
![]() How did BB fill in the gaps in their bumper. Oh wait, they showed the finished product from above so you couldn't see them... What about some black mesh screen to fill in between the bumper and "Porsche" reflector? |
Oh, and their little bumper brace extensions look like crap. Either make a new one to replace the entire brace or use a tube to fill in the gap between the brace and bumper with a longer bolt. Then paint it black.
been there twice, i understand when you buy fiberglass parts, usually some work is needed to make them fit,..sanding, heating, filling holes, not cutting parts into 4-5 parts only to fibgerglass them back together,...
i have a 2004 sti with some fiberglass parts and carbon fiber parts and all of them FIT SPOT on with no work 1. http://forums.pelicanparts.com/paint-bodywork-discussion-forum/555943-anyone-have-fitment-issues-renn-speed.html 2.http://forums.pelicanparts.com/paint-bodywork-discussion-forum/560580-another-renn-speed-fitment-issue-what-do.html good luck, its a pain, but its worth it in the end i guess |
Of course this was after I gave up on the Better Bodies front RSR bumper which simply would not fit over my oil cooler no matter how much I cut off of it. Eventually there was just a massive hole in the middle of the bumper from all my little trimmings and it still was not within an inch of fitting under my front bumper lip. Unreal. |
Crotchety Old Bastard
I had that bumper on my car for about 10 years. Didn't know about an install video, we just used screws every 6 inches all the way around. It took a bit of manipulating but not bad. Very little prep work was needed. I don't have any heat shields or protection of any kind and all is well. This bumper has a huge amount of air space.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
That's exactly the shot I was looking for Brian! Should keep me motivated!
I really liked this bumper and long for the day I can put it back on. The large gap under the reflector lets out a LOT of hot air from the exhaust. That is likely one reason the bumper doesn't get too hot in regular street driving. It does get hot at the track but no melting paint.
I left the rubber bumper seal in place. It does not hang down along the large air gap area. There also is no impact protection, the bumper is simply bolted to the car. I lost something like 75 pounds off the ends of the car, can't remember the exact figure anymore.
first two pics show how far out of whack the flares were. prob 8 hours total to get to this point, fit is much better!
The result is beautiful..
Thread Tools | |
Rate This Thread | |
