Crotchety Old Bastard
Stock Replacement Intercooler Install
Installed my stock replacement intercooler on a gorgeous low mile M505 today. This collector quality car requires bolt-on enhancements that work with the stock equipment. No mods to any other supporting parts are allowed. It was a great opportunity to fitment test my intercooler on another 930. I found a couple of very minor things that I will change going forward. The goal is to bolt the replacement intercooler on without removing anything but the stock intercooler. A 15 minute job.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
OFF THE BOOST PIPE NOW...
Looks great! And so does the M505...
It's a beautiful car.
Brian. . . is there no room for the IC thinkess to go above the AC compressor?
If not. . . What do you consider more efficiant IC, thicker but not go all the way across. . . .or thinner and be able to go above the AC compressor?
theres nothing like the rear end squatdown of a turbo |
Interested to hear any performance (cooling) figures from the new IC.
I like the idea of being a 'bolt on' replacement but am also interested in the performance improvement over stock? Looks good installed regards Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1971 911T Targa - twin plugged 2.7 230HP SOLD! 2/2008 1970 911T - ivory white -SOLD 2/2012 1987 930 - sold 2018 1984 Carrera 3.2 RSR look |
Wunderbar!!!!!!!!!!!!!!!!
![]() Brian-- I noticed on the pic, is that an opening-(closest to firewall) u can put a 7th injector or whatever u please. Walt Last edited by wjfk32; 09-07-2010 at 05:59 AM.. |
The emphasis for this design is stock replacement fitment. The core is the same type as OEM but is twice as thick. It takes up all the space available without modification to existing parts in the engine bay.
Yes there is an M18 bung located near the throttle body. It can be used for a variety of things such as boost measurement (using a stock sending unit), injection, whatever. What you don't see are a variety of 1/8NPT bungs on the underside, also for use with monitoring equipment or boost sending units as needed to run other applications. I include plugs and barbed fittings for the NPT bungs. I ran this unit on my car with a 965 BOV and used a stock boost sending unit plugged into that 18M bung to feed the LM-1. I am working on a design for a full bay unit but do not know how the A/C condenser will impact the cooling ability of the intercooler. It would be of questionable benefit to have half of the intercooler under the stock shroud and the other half with hot air blowing through it from the condenser. If anyone knows how hot the condenser gets I'm all ears (my car does not have one so I cannot measure it). As always I will offer these to our host once we have some longevity data with no issues.
Thank you, for the explanation. I do need an upgrade/stock fit plus the xtras u have with it. You did your homework well!!!!
The only thing i need to do is pull the trigger.... Thnxs Walt Last edited by wjfk32; 09-07-2010 at 09:27 AM.. |
Thanks Brian. . . .maybe for data-logging purposes you could do some air temp reading before and after cooler of the stock unit and then on your new twice as thick unit. Sounds good!
UNDER CONSTRUCTION!
Brian
Looks great as allways!! sent you an email hope to here from you soon. cheers ed ![]()
Sometimes the first thing that comes to mind should be the last thing that you do! ![]() |
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) |
Yeah, in Texas an AC delete on a street car is a no-go IMO.
Thread Tools | |
Rate This Thread | |
