Turbo gauge inop
just bought my first porsche. the turbo gauge does not move? how do I know if its the gauge or the turbo? What should I be looking for?
If yes and the gauge still does nothing, take the spade off the boost terminal at the back of the instrument, boost gauge should peg with power applied. Connect to ground the boost sensor terminal to ground, it should read nothing. If not, it's the instrument. Now you get to check the boost sensor - which the resistance of which should vary according to pressure. If that all checks out, look for the sensor wire to be shorted out to ground somewhere/somehow.
'77 S with '78 930 power and a few other things. |
beancounter
First of all, welcome to the forum...and congrats on your new car.
This is why you were asked: Spuggy has given you great info about troubleshooting your gauge. Assuming your engine is in stock configuration, the sending unit for the gauge can be found under the intercooler and is item#14 in this diagram: ![]() Enjoy the ride sir.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
we checked the sending unit and there are two posts, one upper and one lower there is nothing attached to the upper post and I made sure the lower was tight. When the key is off the gauge is below 0, when I start it up it rises to 0? I believe the turbo is working because its the fastest car I have ever driven but I dont like seeing the gauge at 0.
