ceramic exhaust ports
Does anyone know if the 91 c2 turbo had ceramic inserts in the exhaust ports? I ask because the turbine wheel is damaged on my car yet the car was running fine, no smoke good idle etc. I'm going to do a leakdown to be sure nothing is radically wrong.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
No it does not have ceramic inserts, hope it turns out ok. you may want to remove the exhaust syst. and look it over closely.
Lou / AERO DYNAMICS |
Almost forgot, If you still have the air injectors in the exhaust ports check those as well for any missing pieces.
Lou/ AERO DYNAMICS |
Thanks, I hope it's something downwind of the exhaust ports!
Forced Induction Junkie
Factory or aftermarket headers?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Manassas, VA
RS,
My turbine wheel had damage too. I suspected the air injector nozzles because there was very little left of them in the exhaust ports. I have since removed the air system and plugged the ports. Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Stock headers but straight pipes after no muffler or cat.
Mark, so there was no other damage to your car except the air injectors? I really don't want a teardown right now.
We're going to pull the air injectors. Will this give a check engine error? I wouldn't think so since I'm not running a cat and didn't get any errors when I did that.
Manassas, VA
RS,
Here is the damage to my rotor, there was some pitting in the hot side casing too. ![]() Here is a shot looking into the exhaust ports. The port on the left shows the air injector nozzle is about gone, the others are in stages of destruction. ![]() I'm fully healed now. Good luck with yours. Mark
No it will not illuminate a CEL, The control unit in your car does not have this capability , Recommend you set the system to run open loop and adjust to match,Hope everything works out!
Could be the air injectors, but also keep in mind that any carbon breaking up in the combustion chamber or port will impact the turbine blades at speed. There's a lot of kinetic energy in a turbine blade spinning upwards of 100,000RPM.
I'm waiting on a turbine, KKK is out of stock and it will be a few days to get one in. I just want to make sure that we find the problem before we put the rebuilt turbo in. I sure hope its just the injectors. Our thought was that carbon could not damage the turbine in that way. The fans are pretty stout, but we'll see. I haven't a picture of the wheel as it was taken apart at the turbo rebuild shop, but he called to say it was pretty bad. Probably a lot like yours Mark.
Manassas, VA
RS,
I replaced the center "cartridge" of my turbo because KKK was out of stock when I needed one too. It is less expensive and comes pre-balanced, so it bolts right in. Good Luck, Mark
Lou and Mark, Thanks for your spot on diagnosis. Two of the air injection nozzles had lost their tips. We removed and plugged. We got the turbo back after 6 weeks, both cartridges and wheels were out of stock. Mark, my impeller looks just about like your picture. It should be up and running later today.
Thanks to all for your input. I highly recommend that everyone either remove and plug your air injectors or change nozzles every 50,000 miles.
Thread Tools | |
Rate This Thread | |
