930-78-3,3 thermo time switch ??
Hey where the engine sits thermo time switch.?? I can not find it.
regards John
Old 09-16-2010, 09:17 AM
full quack's Avatar
Send a message via Yahoo to full quack
On the engine block, in the back, below the fuel distributor, just to the left of the case seam.
Mark
Old 09-16-2010, 09:28 AM
Top left corner of the left side chain case cover.
Mark
The one mentioned above is the emissions oriented thermovalve that blocks vacuum advance from making it to the vacuum advance pot on the distributor until engine heat migrates up to it, and then it opens if still working and lets vacuum advance start to work.
The purpose of that thermovalve is to block vacuum advance when it's cold so timing is retarded enough to raise exhaust temperature which heats up the catalytic converter faster and lowers emissions after a cold start.
I don't know if a euro car has one because they didn't have catalytic converters in the mid eightees.
Old 09-16-2010, 09:38 AM
full quack's Avatar
Crap...I had my last project stuck in my mind...so sorry. JFairman is spot on!
Mark
Old 09-16-2010, 10:12 AM
I can only see this connector is it to?
Old 09-16-2010, 10:39 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Look towards the back of the car, left of the crankshaft and on the far left side of the timing chain cover. Should have two wires connected to it.
Not my engine, but see attached picture:
Old 09-16-2010, 01:17 PM
stevie 77 930's Avatar
Here's is were mine is....
1983 911SC
1974 914
2018 GTS
2019 Audi S4
'76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 09-16-2010, 01:22 PM
mark houghton's Avatar
Glad that's not your engine! Looks like a boat anchor.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 09-16-2010, 03:30 PM
Thank you. for your great help.
Regards john
Old 09-18-2010, 01:36 AM
Alan L's Avatar
Nope. That is your throttle airplate safety switch - if I am seeing all your pic.
Airman is correct and gets the prize.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 09-20-2010, 07:05 PM
opps....wrong one. Here is the correct thermvalve for that connector
1983 911SC
1974 914
2018 GTS
2019 Audi S4
Old 09-21-2010, 07:12 AM
How do I measure the thermo time switch, to see if it is ok?
Regards John
Old 06-05-2011, 08:41 AM
Ken911's Avatar
what is it's function anyway?
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 06-06-2011, 04:04 AM
Banned
It triggers the cold start injector . . .
Old 06-06-2011, 08:16 AM
Alan L's Avatar
It cuts the Cold Start Valve off after a few seconds. They CSV fires extra fuel via injector straight down the intake throat below the throttle butterfly - so it goes to all cylinders.
You dont need this extra fuel after about 20 - 30 secs once the engine has fired up and the WUR takes over. The Thermo switch should cut the power to the CSV after that time. You can check it by hooking a multi meter over the terminals on a cold motor - you should have a intact circuit (Closed circuit - ohms), then it should cut off shortly after motor fires.
Alan
Old 06-06-2011, 11:44 AM
Ken911's Avatar
oh ok
2019 Silverado 6.2L
Old 06-06-2011, 01:53 PM
