Removing Stock 3.3L intercooler this weekend...anything I need to know in advance?
Looking at it, it looks pretty straightforward, but since I have not done this before, are there any nuances taking it off, putting it back on I should know?
Thanks in advance. :D |
Check your o-rings when you have it off for wear and tear. Check them again to make sure they don't squeeze out. I use a little spray on silicone to help ease it on.
Otherwise, it's a snap. |
:D |
You need a 13mm wrench/socket. I have more 13mm wrenches than any other size as it seems like 90% of the fasteners on this car are 13mm. When you get to the heat exchangers, you'll want a deep offset 13mm wrench and I love my 1/4" drive 13mm swivel socket...a money tool for sure, this one and my stubby 13mm racheting combo wrench are my favorite 13mms. You will also need a screwdriver for the hose clamp on the small hose that goes from the intercooler to the wastegate.
This is easy, and if you're going to DIY on this car, you will be removing and replacing the intercooler A LOT, so get used to it and have fun:) Brian B. (aka RarlyL8) once suggested that he'd like his intercooler fastened with velcro since it has to come off and on so much. |
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
