LinkBack | Thread Tools | Rate Thread |
Removing Stock 3.3L intercooler this weekend...anything I need to know in advance?
Looking at it, it looks pretty straightforward, but since I have not done this before, are there any nuances taking it off, putting it back on I should know?
Thanks in advance. ![]()
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!) 1996 Toyota Corolla(der 'clapper') |
OFF THE BOOST PIPE NOW...
Check your o-rings when you have it off for wear and tear. Check them again to make sure they don't squeeze out. I use a little spray on silicone to help ease it on.
Otherwise, it's a snap. |
beancounter
You need a 13mm wrench/socket. I have more 13mm wrenches than any other size as it seems like 90% of the fasteners on this car are 13mm. When you get to the heat exchangers, you'll want a deep offset 13mm wrench and I love my 1/4" drive 13mm swivel socket...a money tool for sure, this one and my stubby 13mm racheting combo wrench are my favorite 13mms. You will also need a screwdriver for the hose clamp on the small hose that goes from the intercooler to the wastegate.
This is easy, and if you're going to DIY on this car, you will be removing and replacing the intercooler A LOT, so get used to it and have fun ![]()
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Thread Tools | |
Rate This Thread | |
