totle's Avatar
wheel offset with Zuffenhausen RSR style
I'm looking at zuffenhaus 17 RSR style for my 930.
See that there is different offset for early- and late 930.
2x 17x9 ET11mm, 2x 17x11 ET17mm for Early 930
2x 17x9 ET30mm, 2x 17x11 ET17mm for Late 930
I have a 78' 930. Would this be early or late style offset?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 09-20-2010, 05:03 AM
agrimmitt's Avatar
Location: Mesa Oaks, CA: Zone 8>PCASB/PCACC/POC/NASA member
Send a message via Skype™ to agrimmitt
The first US Turbo's, I believe were the "Turbo Carrara" offered in 1976, and my guess yours would fall under an early version. Check your owners manual, or give Pelican Tec Support a call; and before you purchase or order wheels talk with the local shop that knows and works on your car. Has the car been lower, camber changed, etc.
But it will look cool in RSR trim!
art
Old 09-20-2010, 05:11 AM
From MY 1980 on, Porsche fitted larger front wheel hub - and ceased using the 21mm spacer that was fitted until then.
If your 930 was manufactured before 1980, you can use front wheels with greater offset - hence the distinction made by Zuffenhaus.
Old 09-20-2010, 08:41 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
