Clutch Pedal Spring ?? (930)
Hello. how much difference is there between these ??
Clutch Pedal Spring, 911 (1974-76), 911 Turbo (1976-77) Clutch Pedal Spring, 911 Turbo (1978-88) maybe have some pictures of a 78- I would be happy ![]() Regards john |
Is this the omega spring on the trans or at the pedal cluster? Could be the way the omega spring mounts on trans from the other post. Either way, why not get the one you need?
