bruni911's Avatar
Simmons rim help
Hi i have a set of 17" Simmons rims they are 3pc and i would like to change the centers, where can i find centers is my question?
Any help will do, i just might sell the rims and tires if i can not get new centers, they where customs made for the 930.
What would they be worth, also any one would like to trade plus cash for a set of 18" 3.6 turbo style of rims?
Old 09-27-2010, 09:07 PM
Jeff Alton's Avatar
You are way ahead selling them and buying the wheels you want. Having centers made with the correct hub pad height, shell reference and bolt circle will be expensive....
What wheels/look are you thinking about?
Cheers
jeff@turn3autosport.com
997 S 4.0, Boxster 2.7 Race Car, Cayman S 3.8, 958 Cayenne TT, VW GTI 2.1 TSI, Mini Cooper S JCW, Cannondale Supersix EVO SRAM RED E-tap, Cannondale Slice SRAM RED E-tap, Giant Roam Hardtail- to ride with the wife.
Old 09-27-2010, 09:38 PM
bruni911's Avatar
I am looking for the 3.6 turbo style or a 5 star rim that's ether 17 or 18
Old 09-27-2010, 09:50 PM
WPOZZZ's Avatar
Cheers
Jeff is the man when it comes to rims. Sell the Simmons and get what you want. Is your car a 930 or 964 turbo? You can also PM Thatcher as he may have some 5 spokers for you.
Bryan O.
77 930
88 Carrera cab
14 535i M Sport
Old 09-27-2010, 09:55 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
What wrong with the centers? They look good to me.
My buddy has a set for his 930 and had to go to the mfg in AUS to just get bolts and sealer to rebuild them.
Old 09-28-2010, 10:39 AM
bruni911's Avatar
Nothing is wrong with them I just want a 5 star like the 3.6 turbo rim I am really not into the mesh design the rims a great I will just end up selling them. What are they worth?
Old 09-28-2010, 11:03 AM
spence88mph's Avatar
I would say the spring plate is a give away
Put the Simmons on ebay, you should get decent coin for them, they're expensive and well made wheels, probably lighter than what you're replacing them with and more desirable to track nerds...
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 09-28-2010, 11:03 PM
pdqcarrera's Avatar
Not to mention the side skirt & stone guard (at least I've never known anyone to backdate them on a 964T
Old 09-29-2010, 10:35 AM
bruni911's Avatar
It's a 1987 930 with g50/50 and full coil overs suspension.
Old 09-29-2010, 10:44 AM
I have built several sets for the 930 guys and they are 8.5 and 11's x 18. RH is a very popular style, and I have Speedline Alessio, and Speedline Daytona's. jdorociak@gmail.com
Jim
Old 09-29-2010, 07:37 PM
bruni911's Avatar
Hey I like the rims with no tires on them pm for the price
Old 09-30-2010, 12:24 AM
Those wheels with no tires are a set of RH 3.6 Turbo wheels, which are copies of the famous Speedline 3.6 Turbo wheel. That set is 8.5 x 18 front and 11.25" rears. To be used on your car you have to remove the rear spacer change to shorter studs, or I can make the wheels with smaller 3.75" outer rims. jdorociak@gmail.com
Jim
Old 09-30-2010, 08:30 AM
Here's another 18x11" RH 3.6 style rim.
This one started out as an 18x10" wheel in correct offset for a 930 while using the origonal 28mm rear spacers. I bought them used for a low price because the outer rim halfs were bent on both rears.
I bought 2 new RH outer rim halfs that are one inch wider than the ones that were on the wheels from Jim Dorociak.
Then I rebuilt both rear wheels with them and that made the rear wheels 11" wide bead to bead with a deeper dish and they fit the car perfectly and clear the calipers with 315/30x18" tires and no spacers.
I cut the studs shorter on the car and rounded the sharp edges with a die grinder and cut off wheel and painted the ends of the studs to keep them from rusting with black enamel.
The origonal spare tire wheel will not fit over the caliper without at least a 21mm spacer so I left enough length on the studs and carry a 21mm spacer in the trunk with the spare to be able to do that if I ever have to.
Here's the right rear.
Old 09-30-2010, 06:50 PM
RH wheels
Jim - that rear 11" looks great and fits the space perfectly. Thank you for sharing. Jim
Old 09-30-2010, 06:54 PM
bruni911's Avatar
Wow looks great I like.....:.
Old 09-30-2010, 09:17 PM
pdqcarrera's Avatar
VERY good info about the spare tire fitment issue. Thanks for the reminder.
Old 10-01-2010, 05:52 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
