turbo bolt: how do I get to it?
![]() I know almost all of you guys are way better mechanics than me. I cannot figure out how to get any sort of tool on this bolt. It is the lower forward facing turbo bolt. I don't have a stubby set but I am not sure that would help. Maybe an extra short stubby from the top? I have no idea how ill be able to get enough torque from such a confined space on this guy. Any tricks to this bolt? Thanks, Aaron Edit sorry for the giant picture ![]()
84 930 07 Exige S |
I use a socket, with a 3/8ths breaker bar attached it barely fits in there and can only turn it a little bit each time.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
thanks ill try that I would never suspect that a breaker would fit in there but Ill give it a shot.
84 930 07 Exige S |
This would be the correct tool:
Roland 930 Turbo '81 Too many modifications to list |
yeah true i dont have any of those though
Harbor Freight has them real cheap.
And at their low price you don't mind grinding the outer circumfrence of the the box end down for more clearance from the exhaust pipe if you have to. cool... i just noticed you posted at 911 am, Ken. |
Champagne on Beer Budget
That bolt is always fun! I've found that a couple of long 3/8" extensions hooked together with a swivel just before the socket coming over the top of the muffler is easiest.. The ratchet is darn near in the passenger fender.
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
I use a crow's foot "wrench" with a 3/8 socket - works great!
Emery 1988 930 coupe - Silver Metallic 3.3L w/GT35R, B&B Headers, RarlyL8 muffler, TurboKraft IC, Tial WG, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ... ![]() |
I think my setup must be a bit differnt because I couldent make a crows foot work (at least an open ended one). My problem is I have an air injection line and the tail pipes in the way from the side. I just got back from sears and they had neither the half moon wrenches or even stubby not ratcheting wrenches in the showroom
84 930 07 Exige S |
Dear front bottom bolt,
I hate you. Signed, aschen Ok I am convinced that there is no way to get to that bolt without cutting, grinding or removing something. I am sure you guys are right but I cant see how a breaker bar or crows foot could possibly get in there. I hav spent hours with all of these tools from all angles and nothing is even close. Do you guys have the non catted muffler and the air injection line like me? my last chance is to try to track down one of those half moon box wrenches. :unamused:. Is it time consuming to remove the turbo drip tank? It would be easy to get to it from the bottom.
84 930 07 Exige S |
ok No air injection that was the first thing thrown in the trash.
OFF THE BOOST PIPE NOW...
I use a variety of tools: sockets with and without extensions, universals, wrenches long and short, etc. It's a matter of having the right tools.
I hear ya I have a decent collection of metric tools and one of the few things I actually like spending money on is tools. I am usually a bit slow in figuring out the right combo of tools required to remove elusive fasteners, but I almost always make something work.
This time I am a bit stumpede though. I think I just need to get some of those 1/2 moon wrenches and maybe start grinding away at some tools. Unfortunately I dont have a bench grinder either. Aschen really needs a bigger garage for more tools. When an elise takes up most of a bay, you know its a small garage ![]()
84 930 07 Exige S |
I found that if you have a couple different brands of box wrenches the right size, including one of those off-set wrenches pictured above, you can get a partial turn from each wrench that has the box end indexed slightly different. It may take a half hour, but it will come out.
Is there any way to take the rear tray off? On my old setup, I had no engine tins and that top bolt was easier as I was getting it from the top.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
I will try Chill Out Freeze Action Penetrant, Kimball Miswest sells it
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars ![]() |
Is it fun working on cars? Im not sure.
Sears and Ace didnt have those half moon wrenches. I did what i vowed to never do again: buy tools from harbor frieght. The half moon wrench was a sloppy fit on the bolt and made from low grade jello of course. You know where this goes................rounded off bolt. I took a hack saw to the air injection line so now I have a little more room to work. What shoud I try now? Nut splitter? Never used one. Seriously cars suck...im gonna lease a 4cyl auto camery and forget about this hobby......
84 930 07 Exige S |
Can you get a hacksaw blade on it? Maybe you can cut just the nut enough to split and not damage the stud.
Patience Grasshopper.... |
What is your ultimate goal in removing the exhaust?
If you are going to throw away the current muffler, one option might be to cut through the exhaust pipe and remove the cat/test tube/muffler. then you get a straight shot at the bolt. I am able to fit a crows foot in there with the square connection hole toward the engine, and then connect a 3/8 small breaker bar or small socket to it and turn it a few clicks at a time and then reset and turn again. If you are now dealing with rounded nut you may have to cut. if you cannot get a dremel in there, then a hacksaw blade with tape over half of it so you can hold it in your hand might work. Or you might be able to get a torch on it though that would be tough.
Tried over the top and all the other ways which I succeded in breaking one of the other upper studs So got a superb low profile chain pipe cutter( Snap on brand ) as the other top bolt was also stuck tight and cut the dxxxx thing off. Sent the muffler out for reweld as it was a Kremer special one. Proceeded to work on the stud with various easy outs which broke the stud even further so now it was flush with the turbo housing. Still no movement so drilled it out cleaned the threads and reinstalled a new better grade stud and the rewelded muffler using better brass nuts in case it needs to come off again. Oh well it is nice now.
Anthony @ Voitureltd Bayside WI. Last edited by voitureltd; 10-02-2010 at 11:16 AM.. |
Thread Tools | |
Rate This Thread | |
