momo hub
I may be wrong, but in my experience when a Momo hub is new it ships with a wire, a horn button ring, screws, and a horn contact ring like a clock spring that is rubber insulated and sits in the bottom of the hub. Can anyone tell me if I am missing something on this.
Thanks, John ![]()
John- I blame and thank the longhood boys of Austin 84 911 Carrera, 78 930 RoW no option sunroof coupe, 64 Corvette, 71 911T, 73 911E, 67 Bronco, 2001 Boxster, '80 SC "Illegitimi non carborundum" |
if you go down to the 911 technical site and search for momo hub you should find a complete instruction. actually you can probably do the search here.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
k thx
hub
Thanks. I had overlooked using the search. I figured it out, but turned out the "new" hub that I bought had the screw holes striped out on the back. Easy fix with a tap and some new screws.
Thread Tools | |
Rate This Thread | |
