Blitzkrieg
Couple ?'s about oil change
Ok, so I'm about to do an oil change BP 20w/50. Drain sump & tank change filter, and just fill tank with 9 or so quarts and start?
Also I noticed when I turn the key on the oil pressure goes right too 60 psi without the motor running. And only goes a little higher when running. Is this normal?
77' 930 10' BMW F800GS 08' Tundra |
OFF THE BOOST PIPE NOW...
Pretty much covered it.
Warm up the engine for a few minutes. Drain the tank. Drain the sump. Pull the filter (check to make sure the old gasket was removed). Install new filter (with a small amount of oil on the new gasket). Fill the tank with 10 quarts Check level and be prepared to add 1 more quart. IIRC, the oil pressure is 1 bar per 1000 RPM. You might have a bad sending unit? |
Blitzkrieg
Must be bad, because it reads 60psi without the engine running just the key on.
Thread Tools | |
Rate This Thread | |
