930-3,3 78 0.8 to 0.9 boost ??
Hello. How many Hp. it will provide. going from 0.8 to 0.9 boost pressure with standard inter-cooler??
Regards john
Old 10-03-2010, 11:15 AM
Tomy's Avatar
it should give you + 20 HP IMO ?
TET930 996 TT 2003 X50 996 GT3 2004
930 1988 black on black -fast...
944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2
911 S 1970 Targa /ex porsche werks car!
911 S 1969 Targa (under rebuild)
Old 10-03-2010, 12:06 PM
.9 bar plus atmosphere (1.9) is 6% more than .8 bar (1.8).
Thus up to a max of 6% more hp it that is the only change.
However it is often less if efficiencies are falling off somewhere like going out of your turbos efficiency range or if the intercooler can not accommodate the increased heat and air flow.
Thus, if it is a stock 260hp car that is up to 16hp. If a 400hp car up to about 24hp.
Old 10-03-2010, 12:29 PM
John,
There is really now way to tell how much HP would be gained, other than running on a Dyno.
I would tell you there are several things that should be done before even considering raising the boost. Verify you have, at least , a European exhaust system and free flow muffler, check correct operation on the CIS system and varify afr's across the rpm range, check the distributor advance and, especially.
retard functions are correct and operating properly, check timing is in spec, add
a larger aftermarket intercooler.
Many may disagree but over-boosting can easily cause fatal damage
if the engine is not modified to accommodate higher boost levels.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 10-03-2010, 12:32 PM
check correct operation on the CIS system ??How do I check it. I must remember to say I run with B & B exhaust/muffler
sincerely john
Old 10-04-2010, 11:26 AM
mark houghton's Avatar
Originally Posted by 911st View Post
.9 bar plus atmosphere (1.9) is 6% more than .8 bar (1.8). Thus up to a max of 6% more hp
Wouldn't it be nice if hp equations were that linear.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-04-2010, 11:36 AM
Turbos love higher octane fuel ( leaded 110 octane without catalitic converter) as a safety margin when adding more boost with the other upgrades mentioned above. Adjustable boost control when changing from high to standard octane levels if you can resist the temptation not to overdo it. Burnt innards can result if not readjusted between fuel octane being used.
Anthony @ Voitureltd Bayside WI.
Old 10-04-2010, 02:41 PM
