Tomy's Avatar
Clutch slipping vs high boost
I have such situation in this week. I found that my boost coming just above 0.8 when normally it was max little above 0.7 so it was strange to me. Next day I found that my clutsch slip a little between 4500 to 6500 rpm. Today I drive to make some tests and found that my boost going even near 1 bar! Of course I have clutch spinning feeling too.
What it can be?
I have put Brian free flow exhaust last 500 miles as well as new turbo K7200 too. I take round 400 lbs of weight out too. Could it make such results? By the way I not found clutch smell and I surprise what is going on. Any idea?
TET930 996 TT 2003 X50 996 GT3 2004
930 1988 black on black -fast...
944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2
911 S 1970 Targa /ex porsche werks car!
911 S 1969 Targa (under rebuild)
Old 10-03-2010, 11:16 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Try adjusting the clutch, but you may need to replace it. Usually a stock clutch is good to 400 HP, but if you can spring for a KEP Stage 1, give it a try.
Old 10-03-2010, 12:42 PM
Turbofrog
smurfbus's Avatar
I would first figure out the overboost issue unless it's wanted. Your wastegate boostline could be leaking. The clutch might still grip with the lower boost but maybe now you got addicted for the extra power and don't want to go back? In that case check the fueling so it does not get too lean with the extra air.
Old 10-03-2010, 09:06 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
