whats this wire?
doing the first oil change and wanted you guys to look at a few pictures. I am trying to get rid of the oil leaks and getting everything cleaned up. THe first picture shows a wire that is under the heater control that is between the seats(the picture is from the underside of the car) the wire is just hanging there and I don't see a obvious place to put it. the second is the bottom of the transmission, I have a slow leak out of the bottom of the transmission, It looks like its coming from the seal but I cant be certain.
84 930 Slant 15 Sonata 2.0T 08 Ram 1500 15 Ram Eco Diesel |
OFF THE BOOST PIPE NOW...
It's hard to tell what the first picture is showing.
I'm trying to think what's under there to hook it up to: 1- reverse light switch 2- auto heat control 3- speedo sender 4- On the second picture, you just need to pull the guide plate, clean the surfaces and and reinstall with a new paper gasket. I used a sealer similar to the case sealer. |
thanks for the input. I know the back up lights work, so I can check that off, the other 2 I will look into. thanks
Thread Tools | |
Rate This Thread | |
