16Volt's Avatar
PLX Wideband
Is anyone running one of these?
PLX DM-6 SM-AFR | Wideband Air Fuel Gauge
Knowing the AFR is always good and I like the ability to run multiple sensor inputs through it (my days of 9 different gauges are over). It would be trick to just add boost, EGT and oil temp into the same gauge.
I used to run a LM1 from Innovative but I hated the 30-60sec wait time for the WB to warm up before you could start the car, not to mention the bulky controller box (this is back in the early 2000s mind you).
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 01-17-2014, 09:29 AM
I have one in my car. AFR, boost, and oil temp. It is built into my tach, it was done by a guy that doesn't build them anymore. I like it.
PLX Boost & AFR Gauge by willtel, on Flickr
1987 GP White 930
1977 Ford Bronco
Old 01-17-2014, 10:26 AM
16Volt's Avatar
Ive seen yours will, that is excellent. Did you have to extend any of the wiring to reach the dash? Are your modules mounted in the engine bay?
Old 01-17-2014, 12:00 PM
tops911's Avatar
I have one like will's, I have the module (AFR) under the seat and the other one in the front trunk. The AFR wiring went from the O2 sensor to the module under the seat, so that's why it's under the seat. I would have preferred both in the trunk, but it's fine. I did not have to extend any wiring, there is plenty of wire provided with the modules'
I hope this helps
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 01-17-2014, 06:31 PM
930/66's Avatar
Plx
I had installed the PLX system.
The display (a DM-200) I've built in an old manual boost pressure display (instead of the clock).
The modules I have mounted under the driver's seat.
The system has worked well
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 01-18-2014, 12:51 AM
83 911 Production Cab #10
JJ 911SC's Avatar
I had mine "temporary" installed mine at the ashtray location but will move it as per Thomas installation.
Who Will Live... Will See
Old 01-18-2014, 02:47 AM
cliyde's Avatar
I have the DM-100
G-Body 3.6 Transplant
Old 01-18-2014, 04:54 AM
H2odiesel's Avatar
Timing is everything! I wish I had seen this a few weeks ago. I've recently ordered AEM Seperate. AFM and Boost gauges and still need Fuel pressure. It would have been great to get this info all on one gauge, save some money and get to keep my radio. I wonder if I get the PLX fuel pressure and DM 6 display if it can display the serial output from the AEM gauges??
Old 01-18-2014, 04:55 AM
Looks nice. Does the $199 include everything you need to run an AFR monitor? Couldn't tell from the site. Seems like everything is seperate?
Bo
Old 01-18-2014, 06:24 AM
Uncertifiable!!!
Uwon's Avatar
My PLX is built into the clock housing. I can toggle between boost/vacuum, AFR, post I/C temp, and ambient temp. Particularly usefull in tuning the Electromotive tec3r. Great value.
Johan
Old 01-18-2014, 07:01 AM
16Volt's Avatar
Excellent, I got a little overeager and pulled the trigger last night. Until I am happy with the AFRs I think it will temp mount in the lower left corner of the dash. Once done I will have to find another solution, too bad that guy isnt still doing the tach integration.
Does anyone have an pics on how he did it? I assume its just a dis-assembly, new face etc.
Wiring wise I would really like to put it all in the frunk. Is there any harm in extending the O2 sensor leads (added resistance with the extra wire etc)? 930/66 your mounting plate is exactly what I had in mind.
Old 01-18-2014, 07:38 AM
16Volt's Avatar
Oh, and I was thinking about mounting an on/off switch using a power mirror selector switch next to the existing one. It would be nice to be able to turn the gauge off completely (I like a dim interior at night). I assume this functionality is not already built in?
Old 01-18-2014, 07:42 AM
Uncertifiable!!!
Uwon's Avatar
Originally Posted by 16Volt View Post
?.......I would really like to put it all in the frunk. Is there any harm in extending the O2 sensor leads (added resistance with the extra wire etc)? 930/66 your mounting plate is exactly what I had in mind.
16 Volt,
If you are considering incorporating a boost/vacuum module, then it should be placed close to the motor thereby shortening the length of the small boost/vacuum hose, otherwise it may result in sensor lag and/ or bad readings. The modules should be away from heat so the more obvious alternatives would probably be on the back wall by the rear footwell under the carpet overhang or underneath one of the front seats. I have the same setup as 930/66 with all the read outs incorporated into the boost gauge housing. You can choose to show one large reading (great at the track) or several smaller readings.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 01-19-2014, 06:56 PM
930T Owner
Hams930T's Avatar
I like the idea of taking apart a clock or boost gauge to use to mount the display. I hadn't thought of that. I was planning to buy a blanking plate and drill it 52mm to mount mine.
The PLX setups are really nice. I've used their sensors in my other cars for years with great luck. Always be sure to buy from PLX direct as it's less haggle if you ever have a warranty issue.
Chris
Hams930T
2017 Turbo S
Old 01-19-2014, 10:30 PM
16Volt's Avatar
Looks like I need to bump this as its become higher on my priority list. I received everything from PLX a few weeks ago (both the boost and AFR modules.
I'm not familiar with where the 911 has wiring pass through into the cabin. What did you folks use?
I am going to follow your route Thomas and mount to a plate under the drivers seat. Did you tap power and ground there as well? Any color code info?
Does anyone know if the display can be turned off completely? Is there a warmup time to the O2 sensor? My old LM1 had that and it was super annoying, if you didnt wait then you could kill the sensor after a few startups.
Thanks again folks.
Old 02-18-2014, 07:10 PM
Banned
wiring pass thru = left rear corner of left rear foot well, there's a grommet - go under carpet and you'll see it
need cubic arseload of wiring to get it back thar, over the river and thru the woods and over the fender arch and around the rear bumper, etc.
Old 02-18-2014, 07:14 PM
16Volt's Avatar
By left I assume (making an ass out of you and me) you mean drivers side.
Is it a small grommet? The o2 sensor harness plug is large, I suppose I could depin it and splice in some extra wire. Never heard if that is an issue with sensor accuracy....
How did you other folks manage?
Old 02-18-2014, 07:25 PM
930T Owner
Hams930T's Avatar
You can go through the shifter tunnel and out the car that way... Pretty simple.
Hams930T
2017 Turbo S
Old 02-19-2014, 12:06 AM
Tinkering Pays!!
mooney265's Avatar
I have the PLX setup in my tach. Went through the shifter tunnel/boot... All of my "device modules" are mounted in my center console. BTW: I always have it set to view the "AFR Graph." I like that because it gives a 3-second history of my AFR's. So, I don't be staring at the gauge when boosting
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 02-19-2014, 05:06 AM
16Volt's Avatar
Great, so it sounds like there is enough wiring to reach where it needs to go then without any harness lengthening.
Old 02-19-2014, 06:17 AM
