For those who installed a CHT gauge
Did you install CHT with the sensor located under the spark plug? If so, what sensor you used and what did you have to do to make it fit? Seemed there is virtually no room for the sensor in the spark plug hole.
Here is the sensor I am thinking of.
Dakota Digital - Digital Instrumentation and Accessories
thanks,
anthony
Old 10-14-2010, 02:07 PM
Tinkering Pays!!
mooney265's Avatar
that will fit... looks like mine... you just need to bend the end [with the wire on it] towards the top of the plug...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 10-14-2010, 04:06 PM
Thanks!
Old 10-14-2010, 07:12 PM
beancounter
jwasbury's Avatar
I also have something similar to this. No issues fitting it. I actually made my own using regular K type thermocouple wire, and used a large ring terminal purchased from a marine supply store.
Mooney, which cylinder(s) are you monitoring and what temps do you observe. I'm curious to see if we are in the same ballpark. I monitor #6, and it typically hangs around 150 celcius at top gear highway cruise. Gets hotter on boost and also runs hotter in the summer on the 90-100 ambient days.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 10-14-2010, 07:54 PM
Tinkering Pays!!
mooney265's Avatar
Usually around 140-C. Can get up to 150-C. Located on #6
Old 10-15-2010, 06:07 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
