Canucks Fan
Question Wierd acting 87
Hi Guys
My 87 930 starts great and after a short warm up, I take it out, after about 2 miles it starts to run ruf, like its alternating between 4 and 5 cyl, the tach also bounces and goes to about 5000 when its barley at idle, seems like it wants to stall, I limp home and scratch my head.
The head scratching I can deal with, anyone have any ideas where to look for my problem, battery has full charge and the alt is putting out according to a test that I preformed from some other advice I got here.
Finn
Old 10-17-2010, 03:46 AM
Rocket Scientist
The symptoms you describe are often seen with a CD box failure, a coil failure, or problems with the wiring between the two.
Old 10-17-2010, 06:05 AM
Forced Induction Junkie
WERK I's Avatar
Also, check the output of your alternator/battery. Minimum of 13.5 VDC when engine is running.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 10-17-2010, 06:58 AM
I agree with Werk-alternator/battery.
Old 10-17-2010, 07:24 AM
mark houghton's Avatar
+2. This rears it's ugly head periodically on the forum. Bouncing tach and poor running usually point to alternator/voltage regulation issues....and/or poor grounds.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 10-17-2010, 08:20 AM
i agree with all above, sounds like it could be a cd box and or coil failure, also sounds more like an overcharging issue then a weak battery. check the battery with car running if you rev it and it goes past 16volts you have a bad voltage regulator
Old 10-17-2010, 07:21 PM
Rocket Scientist
That is a good point. Overcharging would also cause this problem and still leave the battery charged.
Old 10-18-2010, 09:48 AM
had it happen
Over charging,smell the battery?? mine was the regulator tach bouncing etc
Old 10-19-2010, 01:33 PM
