-   -   Crank pulley bolt torque specs? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/570388-crank-pulley-bolt-torque-specs.html)
A930Rocket 10-18-2010 08:52 AM
What are the torque specs for the crank pulley? Looking in the manual, there are two numbers, 80 and 170 ft lbs for two different items. I have the double pulley (Alt and AC), but wanted to make sure I'm looking at the right animal before I crank up 170 ft lbs on the bolt. It just seems high...
http://forums.pelicanparts.com/uploa...1287420713.jpg
Turboo934 10-18-2010 09:12 AM
It's80-170nm or59-125 ft lbs
A930Rocket 10-18-2010 09:22 AM
Thanks, I set it at 100 ft lbs, so it looks like I'm good (although I usually max it out :) ).
Just realized I was looking at Nm's as well...
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
