looking for a used interim turbo
Gents,
Posted to the classified, figured I'd hit up those close to my heart... Looking for a fully functioning turbo to run in my 82 930 while mine is being repaired. DO NOT want a beat core or one that needs rebuild. Had a nice talk with Kevin@ultimate and he suggested I go this route along with a couple oil changes to remove any potentially lingering contaminants before they destroy my soon to be rebuilt Hi FLow. From 3ldz on up considered, k27 7006? 7200? Email with price/condition/style. Much appreciated!Thanks! Tom slivan@verizon.net |
You need a turbo to run your car whilst yours is rebuilt? That just is not right...
I have a 65,000+ mile 3DLZ that's been in a box for 3 years. I recall slight side play, but spooled up fine, hit hard and held 12.5 PSI for as long as you had both road and man parts. Pay shipping and you're welcome to use it until you get yours back. If you're interested, PM me. |
Kevin suggested the same thing to me as I needed to break in a fresh motor, before mounting my freshly rebuilt K29.
You definately want to use a used turbo to break in the new engine. Here's a pix of my new HFS after 20 miles of no boost break in driving.... :eek:
I second that BIG TIME.
Been burned enough by common mistakes made while installing a new turbo. You don't know what caused the damage until you get the turbo back in your hands. It then becomes VERY obvious. And of course it is always the turbo's fault because the shop that installed the cheap shrapnel laden headers or put a tube of silocine sealant on the oil gaskets that ended up in the gournal or let the part-time high school kid drive a freshly installed turbo around the block on full boost or installed the new turbo during a complete engine build and let gunk laden break in oil flow through the new turbo, the list goes on and on, isn't going to buy another turbo or pay for a rebuild ... Yes please do use a sacrificial 3LDZ. It is cheap insurance. |
Tom |
Can someone explain why you use an old turbo on a rebuilt motor? Is it to benefit the engine or the turbo?
Freshly rebuilt engines have many ways to take out a turbo. Break-in goo in the oil ends up in the turbo housing, excess sealants can go anywhere, and that nut you can't find is in the header. I think Rocket found that one.
I'mnot exactly sure what happened to mine, but Kevin at Ultimate said it was FOD. I did have new GHL headers and all I can think that happened was that I set my timing incorrectly and ended up having it retarded. This may have caused the headers to get too hot and dislodge something.
Glad I read this, I would of never thought my future rebuild would kill (or have the potential to kill) the turbo. |
No one ever went changing out turbos on new 930's after breaking in the new motor and I never heard of that on any other new turbocharged car, so why would you say thats recommended after a new rebuild?
That sounds like some very incorrect internet hearsay. |
That's a good question Jim. I have some show and tell and you can draw your own conclusions (I've drawn mine).
In this exhibit the "mechanic" who rebuilt this engine thinks more is better when it comes to silicon on the oil line gaskets that should be installed dry. This snotball ended up blocking the turbo oil journal. http://forums.pelicanparts.com/uploa...1288928771.jpg This is what is left of a washer that apparently fell into the header. Result was something like what Rocket posted. Cheap header FOD will do the same thing. http://forums.pelicanparts.com/uploa...1288928889.jpg And this is why you put the O2 sensor after the turbo. Yes I'm sure breakage is rare but the results are devastating! It appears the O2 sensor tip jammed the turbine wheel causing the shaft to break and the wheel to explode. http://forums.pelicanparts.com/uploa...1288929137.jpg |
Not a precaution the shops I used have taken either time my motor was apart - no problems. It would kind of suck to turn a $2,000 turbo into scrap though... |
I've come across only one shop in five that immediately owned up to a blown turbo being their fault and paying for it. All the others denied any culpability and blamed the failure on the turbo. In 2 of those cases the second turbo installed failed as well because the probelm was never fixed. The customer took the beating and paid for it all then drug the car to another shop.
I am sure this happens with all types of cars, you just don't hear about it. You have to know and trust your mechanic. |
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
