surfpangea
Sam Matthews's Avatar
making a stock WUR adjustable
I found this in the 911 tech forum will this work on the turbo model has anyone done this if so I would love to see pics as I am in the learning process
Thanks Sam
http://www.pelicanparts.com/techarticles/911_warmup_reg/911_warmup_reg.htm
MB CL 600 6liter V12 daily driver
86 Corvette Stage 1 Nos (sold)
78 911sc Targa (sold)
77 930 stock 3.0 gsf header ,borla exhaust,gt30 BB turbo, V-band, full bay IC,WMI, 46 mm Adjustable waste-gate,Zeitronix wideband, Intergrated Car pc, Winlog interface Beta
Old 11-05-2010, 12:23 PM
Yes, but it doesn't address the cold control pressure or boost enrichment, which are also useful adjustments to have - Brian Leaske modifies both of these to be adjustable as well.
Modified my WUR
'77 S with '78 930 power and a few other things.
Old 11-05-2010, 01:37 PM
surfpangea
wur
Thanks for the link
Old 11-07-2010, 07:32 AM
Here are a couple of low quality pics of when I did mine. You can see where I installed a small pin to keep the plug from rotating.
Hope it helps.
Old 11-07-2010, 11:52 AM
89 930.
Benny771's Avatar
nocarrier,
you didnt disassemble the wur?
It cant be that easy.... im hoping.
If your thinking of making it adjustable, here is another great link. calibrating the WUR?
Old 11-07-2010, 05:27 PM
Benny, The first one I did I took apart so I could figure out how deep I could tap the plug and drill for the locating pin.
The next one I did I didn't neet to take it apart. Just remember to install the locating pin before drilling and threading the plug otherwise it might rotate on you.
-Adam
Old 11-08-2010, 06:07 AM
surfpangea
Wur
Thanks for the pics
Old 11-08-2010, 06:27 PM
surfpangea
what size roll pin did you use
Old 11-08-2010, 07:09 PM
As a WUR and Fuel Distributor rebuilder, posts like this are what caused me to have to buy a cnc lathe to remake the parts you destroy in doing this because you found 1 out of 4 adjustment points on this WUR. Contact me and tell me what you are trying to do and I can give you some help, this is not the solution to warm control pressure problems.
Larry Fletcher
CIS Flow Tech Llc
Old 11-10-2010, 06:16 PM
Ultimately, I have to admit that Larry is right.
If you look closely at the first WUR, you can see that it is not the correct one for a 930 as there is no boost enrichment port.
The one that came on my car was from a Mercedes if I remember correctly. The car ran horribly. I couldn't get it to idle for anything. The only real reason I ended up modifying mine was so that I could start the car and move it in and out of the shop. I ended up sourcing parts from two. The second one was from a turbo Volvo (I think) I was actually able to get the pressures pretty close if I remember correctly.
I have since gotten the correct WUR and have NOT modified it.
Larry, I have heard your name and shop mentioned a few times by Porsche shop owners as the go to guy for excellent fuel head and wur service. As I am not a well experienced Porsche "guy," I respect their advice and take it to heart.
If someone wants to play with their wur at the risk of damaging it, then that's their choice. If you had to buy a cnc lathe just to repair these parts, then I'd say that's a good thing!
Old 11-11-2010, 06:36 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
