Suspension Dilemma
My 930 puts out about 500 lbs of torque. The rear has 30mm bars on it and the shocks are bilstein sport shocks...
This car has had a history of breaking the hollow core bars.
The car continues to rub the rear wheels because it torques the body down that far when I put the coals to it. What is the real answer on what needs to be done to correct this? Do I add coilovers to the rear to supplement the torsion bars?
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 02-28-2013, 06:50 PM
vas930's Avatar
I would put in the biggest T Bars you can get in it. 33s or bigger.
Get a shock to match it.
Talk to Chuck at Elephant or one of the other good suspension shops.
You may try asking this question on the Track forum.
Some of those guys know a bit.
I think the T Bars and shocks would do the job.
The ride will be firm, but still ok on the road.
Good luck.
If your bilstein sports are stock, they are way to soft if you track the car.
79 Silver 930 SOLD
Old 02-28-2013, 07:19 PM
Tinkering Pays!!
mooney265's Avatar
Looks like heavy understeer... I'd like a pic of mine under hard acceleration. My 345's don't rub, so it must not squat that bad.
I've got coilovers and stock tb's in the rear.
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 02-28-2013, 08:23 PM
Originally Posted by mooney265 View Post
Looks like heavy understeer... .
Well, im in a straight away here...no steering...but your right car looks deeply upset...
I think the coilovers are the next step...That seems to be the suggestion from alot of people.
The coilover conversion kit offered here on Pelican...Has anyone used it?
Old 03-01-2013, 10:28 AM
xbmwguy's Avatar
i had same problem. ended uo using tbars and coilovers works great
Old 03-01-2013, 01:39 PM
Tinkering Pays!!
mooney265's Avatar
I use Rebel Racing's Coilover Kit... Talk to Clint...
Suspension1
Old 03-01-2013, 01:48 PM
proffighter's Avatar
Is that pic under full load?
If not, I highly recommend to lower the front and lift the rear...
Concerning coilovers, I can tell you that it's a huge improvement in driveability and performance. You won't recognize the car after. Much less squating and shaking when load changes
What I found in my TB years, that with a full fuel tank it's much better behaviour than empty. If possible put some weight from the back into the front
There are several threads about coilovers, just search my name. Much info there
Roland
930 Turbo '81 Too many modifications to list
Old 03-01-2013, 02:30 PM
This was almost full load....with a full tank of gas. Thanks for the comments...I will get right to it and solve this.
Old 03-01-2013, 02:45 PM
vas930's Avatar
Thats the case with most 911, they like a bit of weight in the front.
My Dad would always run plenty of fuel for weight when racing his old 74 2.7.
79 Silver 930 SOLD
Old 03-01-2013, 03:03 PM
