Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
wjfk32's Avatar
Das ist mir bekannt.
MSD-coil tends to fail more according to MSD-Forums and made in CHINA.
Walt
Old 03-23-2011, 08:34 AM
proffighter's Avatar
Walt
My stock bought about 10 years ago is made in Brazil. I am not sure if this is an improvement to the one before (leaking too and then failed) from Germany
Roland
930 Turbo '81 Too many modifications to list
Old 03-23-2011, 02:56 PM
DPHANS
DPHANS's Avatar
Hi
I like this project. but dont use a SC fuelhead, If you do, add 3 extra injectors
and also a pressure switch to activate the injectors. This is so simple.
If possible, try to find a a fuelhead from a 928 or a MB 560-1988.
Good Luck
DPHANS
Only Dp 935 cars for me : Dp 935 2.8LTwin Turbo and a Dp 935 Cab 3.0L Twin turbo. Dp 935 3.0L coupe
Visit Youtube= DP935 MANTORP
Old 03-24-2011, 12:32 PM
Tilikum Turbo's Avatar
The factory 3.3L with very low compression ratio cannot run reliably past 0.8 Bar.
A compression ratio of 9.3:1 will greatly limit the boost, so @0.5, that sounds about right.
Are you doing anything to your clutch package to take up that additional Torque? The standard 5-Speed 915 tranny was too weak for a 245HP 1975-77 3.0L Turbo, hence the standard 4-speed on the 930 until much later, when they went to a 5-speed.
Good luck!
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 03-24-2011, 07:50 PM
wjfk32's Avatar
Good luck!
I did a transplant on my 82SC-Targa with a 3.3 turbo-(Top end rebuild 1994)-Cams,polished,7006,AIC-HKS,..ETC..ETC.. My car is at 380-400 to the wheels. Plus being a lightweight car, its no joke. I use my car strictly for HWY-TOP END--60-130MPH +-No drag races.
I did rebuild the 915 tansmission and still have an organic clutch. No problems that area. I have currently 15,000+ miles on the engine and the 915.
Just-relax in 1ST AND 2ND GEAR. You will be fine. INMOP.
Walt
Old 03-25-2011, 05:11 AM
cliyde's Avatar
Awesome project! Just finished up my turbo conversion and will never look back You will LOVE IT!
- '88 911 (3.6 Transplant, Big Reds, Coilovers)
- '12 Audi B8 S4 (6MT)
- SOLD! '84 911 3.2 Turbo Targa
- SOLD! '85 928S 5sp with LSD
Old 03-25-2011, 06:59 AM
one of the great unwashed
patkeefe's Avatar
I recommend a leakdown test when you get it running. Good luck.
Patrick E. Keefe
78 SC
01 Boxster
Old 03-25-2011, 11:22 AM
fzr1k's Avatar
msd makes a coil that can be mounted upsidedown.
82 911 sc coupe guards red sunroof coupe
msd 6al and blaster coil ,cat bypass,9.8:1 comp,heads shaved.020 mild port and polish, 964 cams, k&n filter and cut airbox lid
If I wanted your opinion I'd beat it outta you
Old 03-27-2011, 06:32 PM
TIM.G 911's Avatar
Getting very close
Almost done, only exhaust to go and i should have that fab'd up by monday.
1982 911 SC----SOON TO BE TURBO 911 SC
Old 05-05-2011, 02:55 PM
TIM.G 911's Avatar
Forgot the pics
Old 05-05-2011, 02:56 PM
Tim, where are you dumping the scavenged oil?
THanks
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!----
-1978 911 SC TURBO, Minerva Blue Targa 965 update.
-2008 550i M-Sport
Old 05-08-2011, 07:02 AM
sjf911's Avatar
By the looks of it, he is dumping the oil back into the oil tank vent. It would be nice to see a detailed pic of that setup. This is what I had originally planned on doing before I sourced a turbo oil tank but I hadn't figured out how to make it work while still using a catch can.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 05-08-2011, 07:37 AM
gavinc69's Avatar
Awesome project TIM.G 911 :-)
Any chance of some extra details and images of how you did your customer airbox?
Cheers
Old 05-08-2011, 11:20 AM
TIM.G 911's Avatar
Oil
Oil from the turbo is being returned to the vent side of the oil tank thru an R.B. RACING electric spur gear oil pump and braided steel lines. Exhaust is done just needs bolted up, looks like i will fire it up on Tuesday!
I have very detailed pics of every piece that was fabricated for this build so yes I can and will post up pics of the airbox later this week.
Tim
Old 05-09-2011, 04:29 AM
gavinc69's Avatar
Hope it all goes well Tuesday dude ;-)
Old 05-09-2011, 09:24 AM
TIM.G 911's Avatar
Done!
Runs great! 6.5 psi boost @ 6500 rpm pulling 13 degrees timing air/ fuel was at 12.0 and it felt great! Going to run the existing fuel out, fill it with 100 octane and head for the dyno to see what difference all my work really made. Exhaust sounds fantastic!
Old 05-25-2011, 03:20 PM
Tim thats great news, I hope my project turns out the same as yours.
Jeremy C.
-2008 550i M-Sport
Old 05-25-2011, 03:25 PM
patkeefe's Avatar
So, you're blowing into the stock airbox, I see. I have found that the plastic airboxes leak like sieves. You may want to pressurize it to check. Do you have any backfire protection?
Nice work overall. You will be making a lot more than 240 at the wheels, I'm sure.
Patrick E. Keefe
78 SC
01 Boxster
Old 05-25-2011, 04:18 PM
TIM.G 911's Avatar
Air box
I am blowing thru the stock air box, i did have a few leaks but taken care of, my 1st goal was to get it up and running at 6.5 psi boost assuming the box would hold that kind of pressure with no problem. My backfire protection right now is a spare air box! I am in the process of fabricating a stainless air box which i can tig weld my lid to and be done. By the way i have no lag with this set up it spools very fast. Since 1st goal is met i will enjoy it this way hopefully all summer and next winter approve upon a few areas so i can turn the boost up.
Next goal 14psi!!
Old 05-27-2011, 01:45 AM
How's this build going? Any issues? Still running 6.5psi?
Old 11-25-2011, 11:37 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
