engine drop
Hows my fellow pelicanites. I finished a leak down tests with some poor results on 2 cylinders 11% and 25% sooo engine drop with new rings are planned and probably a clutch. Well I would like to solicite opinions as to drop engine separate or together with trany?
Old 01-13-2011, 06:14 PM
Both at the same time.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 01-13-2011, 06:23 PM
pete3799's Avatar
Drop them both. Much easier to mate the trans./ engine on the floor.
Pete
79 911SC RoW
Old 01-13-2011, 06:25 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Both.
Old 01-13-2011, 07:14 PM
9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
No brainer, ,both.
I've done maybe 5 or 6 drops and every time I look at it and think about trying to seperate those two without dropping them both and every time shake my head and think WTF ?? Why would anyone ever try it without dropping both.
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 01-13-2011, 07:21 PM
Packy's Avatar
sometimes it can be a real pain in the ass to get the tranny separated from the motor (search tranny and motor separation). It's easier to drop both.
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 01-14-2011, 10:31 AM
78P930's Avatar
I've done partial engine drops to pull out the tranny, but would pull both out to work on the engine. I can think of no benefit to leaving in the transmission when pulling the engine. Good luck on your project, and beware of the "while you are in there bug". BTW, where are you located maybe somebody is close by that can help.
Pat
10 Ford Raptor
86 930
Old 01-14-2011, 04:00 PM
sudo apt-get purge 930
equality72521's Avatar
Both, absolutely.
--clutch-monkey
Old 01-14-2011, 04:06 PM
So John, what happened? That car was pulling pretty hard at VIR last fall.
Are you attacking that job yourself? Your question concerns me...
Old 01-14-2011, 04:22 PM
Hello guys and miguel so its settled i will drop engine and tranny togther . Fortunetly jacob is coming up to ct on sunday and we plan to drop the motor . I will try to post some pics. Im planning on just replacing rings because the engine has less than 10,000 miles since rebuild though previous owner replaced fuel delivery with motec m 48 and once we closed loop with o2 sensor it was discovered motor was running lean on boost which im thinking may have contributed to broken rings. I will no more on sunday and thank you everyone
Old 01-14-2011, 07:03 PM
Canucks Fan
Take lots of pic's and what you had to un-hook to get it out , planning on dropping my 3.3 later this year and could really use some heads up "watch out for this" kinda advise
Old 01-15-2011, 09:27 AM
beancounter
jwasbury's Avatar
Originally Posted by Shadetree930 View Post
Are you absolutely sure a rebuild is needed? Did you 'hammer tap' the valves with poor numbers to insure it is not simply a case of dirt in the valve causing the leak?
Cylinders are leaking down through the crankcase breather and he's got exhaust-like puffing of smoke/steam from the oil tank filler when the engine is running. Classic symptoms of broken rings.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-15-2011, 10:37 AM
beancounter
jwasbury's Avatar
Well then .................... WHILE YOU ARE IN THERE ..........................
A perfect post for my 911th post.
Something isn't right with John's clutch too, so we will be addressing that...engine has to come out anyway.
Jacob
Old 01-15-2011, 11:18 AM
tomorrows the big day should be fun
Old 01-15-2011, 07:15 PM
beancounter
jwasbury's Avatar
pix pix pix pix pix
Here is the scene when we arrived (me and fellow pelican Vinny aka VinBarret). John had the car up on stands, sway bar removed, CVs detached. All in his garage which is cleaner than my house. Nice place to work:
Jacob
Old 01-16-2011, 07:46 PM
well today was the big day, although I have to admit I was really along for the ride watching both Jacob & Vinny. For starters, I have to say an engine hoist made life much easier. We were able to lower the engine with the hoist from the top of engine compartment on to Jacob's RV jack, pull it out from under the car & then rehoist the motor on to engine stand. All transitions were VERY smooth. Currently all motor parts are taking up a full bay in my garage. Unfortunately, as suspected, 3 of the cylinders had broken rings. and the best was cylinder #6 having fused rings to a warped piston. (pictures to follow) Looking over the parts, it has been decided that the heads will be going to a machine shop. #6 cylinder & jug needs to be replaced or all new cylinders & jugs.... yikes! ..... and a new clutch, also as suspected. A lot of this could have been avoided with a properly tuned motor. However, that was out of my control. And during my purchase, a compression test did not reveal this issue, if it existed.
Anyway, the joys of owning a Porsche 930. .... with an adventure & $$$ to follow. I have to say, though, it was exciting watching my motor come apart into a million pieces. :-)
Old 01-16-2011, 07:58 PM
beancounter
jwasbury's Avatar
more pix
Lowering the engine
Its out
Engine on stand...deep snow in CT
Longblock---->
One of the header nuts gave us trouble, but Vinny broke its kneecaps and it decided to cooperate:
#6 piston, worst leakdown of the bunch. See anything wrong here?
We found busted rings on 2 other pistons also. #2 and #5 exhaust valves were white...look to have gotten veerrrrry hot.
John's pristine garage turned into a Porsche parts yardsale:
About 9 hours after we started = shortblock----->
Jacob
Old 01-16-2011, 08:00 PM
Turbo Hooligan
John, sorry to hear it man, but they always come back to life stronger and faster! (hint, Hint)
I see cams, ported heads, bigger pistons and cylinders, etc in your near future! why not shoot for 500 at the wheels? Your doing it yourself now and I know between you and Jacob it will put back together better then factory! keep pics and updates coming!
www.d-zug.com
blog.d-zug.com
All these guys do is drive too fast, work on cars, chase ******* and drink.. really no fun at all...
Old 01-16-2011, 08:11 PM
beancounter
jwasbury's Avatar
The heads appear to be ported...need to measure them. Cams are supposedly SC grind. The engine already has 98mm pistons (3.4 liter). It will depend on John's desire and budget as to whether he goes bigger or not.
Jacob
Old 01-17-2011, 06:31 AM
hello everyone. as you can all see, there's some damage to my motor. I would really benefit & like to solicit everyone's opinion regarding my options in my re-build. First option to consider is finding a matching jug & piston which is a mahle 3.2 liter bored out to 98 mm. Or cough up 4 grand for a set of 6 3.5 liter nikies (sp?) that doesn't require my block to be rebored. Or any other options people can think of?? Also during this rebuild I'm going to need a new clutch. would like to solicit opinions regarding types? My engine made 455 hp at the crank. Not huge amounts of power, so I would really like a comfortable driving clutch. Last, I have some pictures of the turbo & would like anyone's input if they can identify what type of turbo it is & what their thoughts are about this turbo.
thank you everyone.
Old 01-17-2011, 07:24 PM
