Gorgeous workmanship! Thanks for sharing!
Rod
"This Year ferrari's Ass is Mine"
Old 07-12-2014, 07:08 AM
Thanks, yours is looking like a nice project also!
I just need to find some free time!
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 07-12-2014, 12:36 PM
Ken911's Avatar
Any pics of the finished tank and how many gallons does it hold now? i was thinking of doing the same thing with mine. Not the internal pump but bigger peick up and rounding it out by removing the inset for the spare tire.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 07-12-2014, 05:56 PM
Chain fence eating turbo
Just saw this thread too! Love you hacked up the tank and redid it with great craftsmanship! Most folks would not want that project. They'd just buy a fuel or something else.
Old 07-12-2014, 06:28 PM
Almost finished the tank this weekend, only one more piece to form and weld in, then it's time for a pressure test. I'll post when it's done, bit it's been quite a job!
I have no idea what the final capacity will be, maybe 3 gallons more?
Increasing the pickup size would be easy with the tank opened up, it's only brazed in.
1986 911 Turbo
Old 07-14-2014, 07:39 AM
Thanks!
I asked myself the same question several times, "Now why did I do this?", because it's been quite the project in itself. One more piece to form and weld, and I'm ready to move on to the pump mount.
1986 911 Turbo
Old 07-14-2014, 07:43 AM
Gas tank almost done
Last piece of the puzzle welded in. A little dolly work, then more flap wheel (or is that cow bell?) and it's ready for a pressure test. The top opening fits two 044's in-tank.
Stock bottom fittings removed and covered:
1986 911 Turbo
Old 08-09-2014, 05:22 PM
This deserves a slow clap! beautiful job man.
I could'a used more cow bell LOL
Old 08-09-2014, 08:36 PM
Nice vacation weekend to blow off the winter dust and get to work!
In my grand plan to update the car, front to back, to modern standards I wanted to get rid of the old style fuses and relays, and add fuses and relays for the EFI and headlights in the process. The relays are buffered 40A sealed Panasonic units, made in Japan. No more overpriced round relays made in China.
Fabricated from stainless, I built it modular so it only takes removal of a few screws to break it down for re-wiring or maintenance. The fuse block is from Fred Cook here on Pelican. The rod below serves to brace the lower block and provide a place to tie off the wires
Fully assembled.
In the car, located to avoid all the bracing. Now I just need to wire it up and test.
1986 911 Turbo
Old 05-24-2015, 11:43 AM
Large Member
krasuskyp's Avatar
Whoa, varry nice werk thar as usual, Win.
Long time no update, good to see you back at it.
Curious, tho... WTF is Ronknees' picture doin thar on the lower left of the first pic of his date night from last night?
Odd...
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 05-24-2015, 04:18 PM
Thanks Paul!
Odd...
I think that was a prom night pic?..........LOL
1986 911 Turbo
Old 05-24-2015, 04:35 PM
Win,
Stunning work- worth a drive from MT to CO just to see it in person.
Phil
Old 05-24-2015, 06:41 PM
Banned
Odd...
Jealousy/envy of my herding abilities does not suit either of yew tew goons!
PS - note the sheep rearing up; that's Paul getting the ole' errrrr, ummmm "cattle prod" treatment right thar!!! Look closely and you'll see a big smile on his mug!!!
Old 05-24-2015, 08:17 PM
911tracker85's Avatar
good lord. seeing this may have increased the length of my project that I am just getting started on.
adding another thread to my list of 'things to do to my 930'.
my 930 clone has the bodywork and the motor, but the guy left SC suspension / brakes. I already got a set of 930 calipers.
have started considering the suspension. not sure I'll be up to what you did, but will consider.
Steve Weiner is also my go-to guy on my build.
outstanding work.
Bob Cox
84 928S, Ruby Red linen/brown interior - preferred DD
85 911 Targa, White Gold/brown int - sold
86 944 turbo my new DE/track car.
78 930 clone project car.
Old 05-25-2015, 06:27 AM
Thanks guys! It's been a very slippery slope, and not enough shop time!
I'm hoping to at least hear the engine run this summer.
1986 911 Turbo
Old 05-25-2015, 06:45 AM
Thank you for posting, and we love pics
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 05-25-2015, 08:14 AM
IMR-Merlin's Avatar
How did I miss this thread? Wow, nice work. I will be harassing you at some point for the COP specs.
I an running EFI in my 930 and was told you only need 1 044 pump.
Old 06-15-2015, 04:53 PM
Thanks!
You probably missed it because of my snail-like pace!.......
I'm running two parallel 044's in-tank to set the stage for a future E85 setup.
Here's a chart for an 044:
If you keep the pressure down to a max of 4 to 5 bar (boost + base fuel pressure) the pump pulls 12 - 13 amps and delivers 3.5 - 4.0 ltr/min flow. Will probably live a long life. If you push the pressures higher, the amp draw and heat go way up, shortening the pump life, and the volume goes down.
I did a lot of research on the COP's, hit me up anytime.
1986 911 Turbo
Old 06-16-2015, 10:39 AM
VZ935's Avatar
Send a message via AIM to VZ935
I run 935 suspension with Moton's too
A bunch of old race cars
Old 06-19-2015, 06:32 AM
On a real 935 that I can only (wet) dream about!......
Damn, that looks sweet!
I can't wait to see how these handle........which is killing me!
1986 911 Turbo
Old 06-19-2015, 08:33 AM
