R.I.P.
drmatera's Avatar
Cobalt - easy, this isn't a debate about whats hard or abusive. road racing is easy on a car? Any type of aggressive driving is "abusive".
since we couldn't see his 60' times for each attempt there is no telling which launch was best... But it is fun trying. Just like hitting the apex just right
Old 02-05-2011, 11:14 AM
Best to have the tires spin than the extra strain that wider and/or sticker tires would put on the drive train. The 930 4 speed is rated for around 750HP as I have read, under I would expect road race conditions. Drag race conditions may not have been considered for the drive train. Also that estimate was derived with Tire technology from the late 70s. I often think of putting a 930 on the strip as I have been there before.
Anthony @ Voitureltd Bayside WI.
Old 02-05-2011, 01:59 PM
Got Boost?
IMONBOOST's Avatar
My 60 time was better with the wheel hop 2.408 but I had to shift very early to second due to the pain of feeling the whole car shaking and the car bogged down due to the early shift giving me a 330 of 6.951. The track was extra sticky due to many low 10 second cars racing that day. I would have prefered a less sticky surface to allow some wheel spin to ease off the line.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 02-06-2011, 06:21 AM
Cobalt's Avatar
It's all good, although hitting the apex consistently in 3.6T is far easier than launching one from a dead start. The 964 turbo is probably one of the most difficult of all Porsche's to launch consistently and obtain times worthy of the car. The car is far faster than it's 1/4 mile times would have you believe. 60-130 is a truer test of it's abilities and with some mods becomes much faster. I personally find no fun in trying to launch a 3.6T, a rolling start IMO offers a better experience without frustration.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others
Old 02-07-2011, 06:09 AM
Chain fence eating turbo
The launch would be a lot better if these motors had a heavy, large diametered flywheel to provide momentum....but they don't. It's all motor to launch these cars. Then you mix in low compression and small displacement resulting in really poor launching ability.
Old 02-07-2011, 07:19 AM
R.I.P.
drmatera's Avatar
your first mistake is shifting early, if it wheel hops just lift off the throttle till it quits then keep going thru first gear. The biggest mistake novice drag racers make is the early shift due to wheel spin or hop. Just because the engine is at 6000rpm doesn't mean the vehicle speed matches it. A shift to 2nd gear at 10 mph will result in horrible ET's.. I figure if you are going to put the car thru the trauma of a launch you might as well get some good results... But as I said before my car has cut 1.77 60' times and i've not had any wheel hop issues.. technique
Old 02-07-2011, 08:16 AM
R.I.P.
drmatera's Avatar
ps. my 330' times are in the low 5's
Old 02-07-2011, 08:18 AM
1.77 60-ft. times in insane for these cars!!!
I would have hit 11.9X's with my car hitting that number.
Old 02-07-2011, 09:53 AM
R.I.P.
drmatera's Avatar
yeah, i ran an 11.79 on that pass. It was a great night at the track as I lined up with just about all of the modern day "muscle cars" from the big 3. Kicked each one of their butts as not one of them ran better than low 12's. I wish I would have seen the look on the face of the GTO driver as I put that 1.77 60' on his ass... I know he was expecting different results judging from the drag radials he had on the car.
Old 02-07-2011, 11:32 AM
Nice
Old 02-07-2011, 12:09 PM
Got Boost?
IMONBOOST's Avatar
Went back today, last time it turned out I had boost leaking from the turbo to IC hose. Here my best result out of 4:
The car is a '94 turbo 3.6 with cat-bypass, LWFW, and stock boost.
-Ayrton Senna-
Old 04-23-2011, 09:14 PM
tj930's Avatar
I've been looking for a thread that an Australian guy posted up a year or two ago. (He had a pretty Stock, GuardsRed, 1978-88 930 and was getting some pretty representative times.)
If I recall correctly, 13.3 Seconds at 106mph with a 300BHP 4-speed car.. So with a more aerodynamic, 380BHP, 5-speed car, I think you should be into the high 12s!
Old 04-24-2011, 06:07 AM
Got Boost?
IMONBOOST's Avatar
tj930, I am sure my car with a great launch and perfect shifting should be good for 12.7-12.8, but I am not abusing the car on the launch. Actually, there were only about 6 to 8 cars doing passes so we had the track all for ourselves but I called it quits, a transaxle fix is not worth having a 12's slip.
I have the Zeitronix log for a 13.2 pass this same night (this one the car lost grip on 1st and I had to ease off) and it shows I am shifting at 6,144, so it seems I am shifting a little short, my tach sure looks like I am hitting more like 6,400 - 6,500. Not sure what to trust.
The other two passes where 13.5 and 13.6 and these were rolling out on first. I am waiting for the right time $$$ to order rarly headers and HFS and see if I can hit 12's rolling first, I will be happy with this and so will be the transaxle :-)
thanks for you input tj930.
-Ayrton Senna-
Old 04-24-2011, 07:00 AM
tj930's Avatar
I had a 'racing' (Kevlar) Clutch in my car at the time and, using a G-Tech Pro, I got a time of 12.8 seconds @ 109mph. But I don't think the tarmac was perfectly level (might have been a bit of a downhill dip) and one really doesn't really want to give one's car's transmission that kind of horrendous abuse very often..
But.. If you did.. I think you'd be getting 12.8s easily! (The 3.6 964 turbo is a beast! )
P.S. I love Aryton Senna, too
P.P.S. If you ever want to sell it, I know a guy in England who would love to buy your 3.6 engine!
Old 04-24-2011, 08:51 AM
Me like track days
Craig 930 RS's Avatar
Brian: What would a 5 speed 3.4 930 with 514FWHP and 2650 lbs do? High 11s?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 04-27-2011, 09:02 AM
Hi Tj930, Not sure if this was what you are looking for?
This was my car at western sydney international drag way on August 2010.
Check the link below. Cheers.
Quarter mile results.
Old 04-27-2011, 09:04 PM
tj930's Avatar
Hi Andy - the very fellow!
I'd got that all wrong, hadn't I, mate? - you had a very 'unstock' car and had returned some absolutely blistering times! (11.396 @ 127.71 MPH )
I just remembered that picture of your car, sat on its haunches, as you launched it off the strip - quality!
Old 04-28-2011, 05:18 AM
Got Boost?
IMONBOOST's Avatar
Hello guys if you care to see the 13.2 pass, see the smoke shooting out the back, thats when I had to let go due to wheel spin and put the power back on:
See minute 4:48 if you just want to see the 965.
YouTube - Sneaky Rental 23 Abril
-Ayrton Senna-
Old 04-30-2011, 12:19 PM
Here are some stock magazine times for reference.
1987 GP White 930
1977 Ford Bronco
Old 05-02-2011, 10:52 AM
Got Boost?
IMONBOOST's Avatar
Wow, thanks, this is going to my archive...going to read it now.
-Ayrton Senna-
Old 05-03-2011, 04:37 PM
