LinkBack | Thread Tools | Rate Thread |
Got Boost?
Stock Turbo 3.6 on Drag Strip
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work." -Ayrton Senna- |
Crotchety Old Bastard
107mph trap speed puts you in the power/weight range to get into the deep 13's or better. Wheel hop kills trannies so stay away from that at all costs. You might look ito better shocks. Once the hop is gone and you get a decent launch you'll be in the 13's without abusing the clutch.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Got Boost?
Thats what I thought, the car should be good for at least high 13s without too much drama. Did not try slipping the clutch because it is brand new and was worried about glazing it after all the $$$ into it. I think I will never try hard launches on the car, but I would love to get at least low 13s with a smooth rollout on 1st and then WOT.
That said, as soon as you have your 965 headers done let me know.
I've never drag-raced my 930 and I never will, but I think someone could get better times than that. I've had motorcycles and muscle cars at the dragstrip- the bike in the 10s and the cars in the 11s. A good time is ALL in that first 60 ft... if you slip the clutch too much, or not enough, or spin the tires, you might as well shut the car down and coast the rest of the way. Any hiccup and you can easily add 1 second to your times.
You cannot kill a bike, and muscle cars are can be made fairly bulletproof for cheap. But the damn Porsche trans, diff, CV joints etc and the associated $$ when the SHTF, no way. I don't blame you for babying it. It's not built for that sticky tire launch.
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS |
R.I.P.
whats your launch technique? I haven't had that problem yet on my 930 and I've been 1.77 60' . I'm betting your 60' was around the 2.40's. With a better launch you should be in the low 13's at 110mph atleast.
Don't feel bad, these cars are not that easy to launch. But get it right and she'll lay down a number you'll be proud of. |
Got Boost?
No technique at all, just put the car in motion on 1st and WOT. The 60 on the second pass was 2.58.
R.I.P.
I like to launch like this
hold RPM to 4000-4500, as I start to apply the clutch I go WOT then release the clutch fully. It reduces the shock to the drivetrain and puts load on the motor to build boost. You'll get a drop in RPM as the clutch bites but the turbo should be spooling by then to help bring in the power. My car is a 4 speed so i don't think you'll need as much "launch" RPM as I use so try 3000 rpm first |
I used to launch my GTX like this.
I would heal toe the gas and brake, hold 3500 RPM and let the clutch drag a little so that I could build up boost. When the light changed, I would slide off the brake, go WOT and dump the clutch. 1.3 turbo with 20 PSI of boost, needed that hair dryer spinning to get a good 60'. I would assume the same is correct for these cars. In a few months when my car is done, I will find out. |
No offense but are you sure your car is 100%? A quick search of the internet yeilds magazin tests of low 12s at 117 mph in 94. With your non agressive launch and Im sure your first trip to the dragstrip in the car I would expect the higher elapsed time. But 14 seconds is pretty slow and the trap speed of 107 is really low. The trap speed is less sensative to driver technique.
107 mph is the right trap speed for a 335i which weighs 400lbs more and has 50 less hp. Agian not trying to be a jerk but the performance seems way too low for a 3.6 turbo.
84 930 07 Exige S |
Got Boost?
Well, I would love the turbo 3.6 to be a factory low 12 second car but I am pretty sure it is not. In any case, maybe a turbo 3.6 S and still that was probably after 100 launches and treating the car like is not yours. That said, I do believe the turbo 3.6 should be an easy mid 13 stock and low 13 with a very good launch.
In my case, I have only visited the drag strip two times in my life and done a total of 4 passes. 2 passes on the 965 1 pass on a Ferrari 308 1 pass on a 911 Carrera 3.0 So I am a non experienced person on the drag strip. Like I said in the opening thread, not my thing. road course, that I do have experience, but thats another story. In the end, I did find out that I have a bad fuel pump and I was running 10 psi. I just closed my manual boost controller to be at factory spec but seems like it just does not work that way. I set the car back to 14psi which is what I usually run at, factory is suposed to be more like 13 psi. Regardless, at the spec that I raced that night, on my way to the track I raced against my uncles mini cooper s with 265whp from 60mph to 140mph and I pulled him like 30 cars. Not the best comparison but at least a reference.
I have run my 3.6T following 993TT's with some modifications and 996TT's, from 40 MPH it will gain on them without issue and pass them if there was enough road. So the cars are not slow just not an easy car to launch. I finally gave up and modified the exhaust for less back pressure and although I have not tested it since, it is far faster than it was when I was using the G-tech getting the 0-20 times of 2+ seconds.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others |
R.I.P.
dumping the clutch is not the secret to good launches with these cars. High revs and slipping clutch are the key. You don't shock the drivetrain
Whatever happened to the handbrake start?
89' 930 LE stock standard 90' 944 S2 also original 75' 914 2.0 |
R.I.P.
those videos prove you CAN drag race a 930... and it's fun as hell
Chain fence eating turbo
That thing made boost early in first gear. Is that stock?
Stock? They can't chirp a tire stock, ha!
Definitely not stock has a light weight flywheel, exhaust work and more than likely some engine mods. You can tell by how he is revving the engine. A dual mass fw will not drop in revs so quickly. this will help with launch times. He also has a boost gauge in place of the clock so i would assume it is modified at least with 1 bar spring or more. My car would spin the tires in stock configuration in first gear. In its current form it will break the tires loose in 1st and again at 5000 rpms in second and 3rd too. So pedal control is critical.
![]() Quote:
![]() Garaget | Ett klipp till mot en annan Lotus Omega... |
Thread Tools | |
Rate This Thread | |
