-   -   WTF 930 trans support / not listed? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/590995-wtf-930-trans-support-not-listed.html)
tadman 02-10-2011 06:33 PM
Does anybody have a spare or know where to find the clutch cable support that is on the side of the 930 tranny, I have had no luck in finding a part number, the closest would be the 915 tranny support # 915 116 613 01 for the SC. And the SC support will not fit the 930 tranny. I could fab a part I guess but thats a last resort. There is a part number for the bearing bracket behind the support #930 116 611 06. This support mounts directly under where the cv joint drive line connects, see red circle. My tranny never had the original support, but the one that someone else had made worked poorly and made clutch adjustment difficult.
Thanks, Tad
http://forums.pelicanparts.com/uploa...1297391157.jpg
Sam Matthews 02-11-2011 01:31 AM
I think I have one let me check at the shop I have two or three of those trannys one has been taken apart and left for dead in the bone yard
tadman 02-11-2011 07:49 AM
Hi Sam, thanks for checking. Part should look something like #23 on diagram.
http://forums.pelicanparts.com/uploa...1297439274.jpg
full quack 02-11-2011 09:49 AM
Hey there Sam,
I could use the trans outer housing section that contains the diff. & bell housing. Mine has some micro cracks at the bell housing bolt hole locations. I don't need the diff. end plates or any internals, just the outer case. Mine is a 1984 year 930.
What do you want for your bone yard unit?
Mark
