EDIS spark plug wires?
What are you guys doing for spark plug wires when converting over to edis.
I saw Boost Engineering has the connectors, I actually just need the clips as I can reuse the boots on the coil pack end. I will need boots for the spark plug end. I understand some have been using kits for a crown vic, but how do these seal. I would like to keep dirt and debris out of the spark plug hole. Can boot collars from a 64 356 be used to seal the hole? The plan was to make some spark plug wires with 8mm bulk wire.
Thanks.
John
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 02-14-2011, 05:56 AM
I have reused the EDIS wire connector and boots. just remove the old wire and with a little work from a needle nose pliers they are reusable. For the plug end I used the early Porsche end with the barbed end for the wire.
Old 02-14-2011, 08:36 AM
Where did you get the spark plug end? It is here at Pelican?
Old 02-14-2011, 10:00 AM
