-   -   catah can (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/593460-catah-can.html)
philip j 02-23-2011 06:12 PM
catah can
Anybody with a good source for a oil catch can? How about someone that has built there own? Lets see what you guys are using. Philip
A930Rocket 02-23-2011 06:46 PM
Look at Summit or Jegs. They have several including one that fits the hose coming off the oil tank filler (that went to the air filter).
I can post a pix tomorrow.
boosted 89 02-24-2011 05:04 AM
I've made a few now. this one here is for my GLH turbo dodge. The second, not pictured yet is for the Porsche, after I removed the factory airbox. Instead of just putting filters on the end of the oil vent pipes I'm putting a small catch can on with a filter on the top. I may also change it from a filter to a fitting to attach
to the top of the air filter..pics soonhttp://forums.pelicanparts.com/uploa...1298552632.jpg
Chris
David 02-24-2011 05:11 AM
Here's my solution:
http://forums.pelicanparts.com/uploa...1298553019.jpg
Here it is installed on the far right side of the photo:
http://forums.pelicanparts.com/uploa...1298553069.jpg
A930Rocket 02-24-2011 08:53 AM
http://forums.pelicanparts.com/uploa...1298566389.jpg
Kraftday 02-24-2011 12:04 PM
I've done quite a few of these, Peterson Fluids Systems makes nice cans. Proper crank ventilation commonly overlooked. In kit form, Jim Patrick of Patrick MS has a good deal going and specific to Porsche.
Serviceable with internal baffles, drain plugs and lightweight aluminum etc...
Patrick Motorsports - PKG OIL BRE SYS-911-914 BREATHER SYSTEM ENGINE OIL TANK OR CRANKCASE VENTILATION SYSTEM FOR PORSCHE 911 AND 914 CONVERSIONS
DailyDriven'88 02-24-2011 03:20 PM
http://i10.photobucket.com/albums/a1...sche930IM1.jpg
philip j 02-24-2011 04:02 PM
A930 Rocket; Thats the can I'm looking for. Any more info on where to source? I checked the links you mentioned, but to no avail. David, nice custom touch, really thinking outside of the box. Philip
boosted 89 02-24-2011 04:46 PM
Just made this the other day..It does not replace the one by the oil tank but is
used for 2 hoses that normally hook up to the factory airbox. Some people just put little filters on them but I figured I'd make something small but neat
.http://forums.pelicanparts.com/uploa...1298594728.jpg
Chris
A930Rocket 02-24-2011 08:21 PM
Try searching for Moroso products at Summut and Jegs. It's not called a catch. can but something else. Overflow tank maybe?
jly535 02-25-2011 01:09 AM
Made this for my turbo 535is, but will be using on the 930.
http://i164.photobucket.com/albums/u...-0100397-1.jpg
HelmetHead 02-25-2011 06:43 AM
I also have the Moroso version in my car. Here is the link on Jeggs
Moroso 85465 Moroso Oil Breather Tank
philip j 02-25-2011 06:55 AM
1" hose connection
I have been looking for a tank with a 1" ID hose connection. I would like to not reduce the vent size from the oil tank. What is the ID of a #12 an fitting. Philip
A930Rocket 02-25-2011 09:09 AM
-12 is just under 1" as I measured mine, but it fits perfectly. No need to squeeze down the hose.
Here's the link: Moroso 85465 - Moroso Racing Vacuum Pump Breather Tanks - Overview - SummitRacing.com
Sam Matthews 02-25-2011 11:34 AM
looks like jegs is beating summitt by about 4 bucks on the moroso
A930Rocket 02-25-2011 12:42 PM
Even with shipping they beat Summit by a couple of bucks.
philip j 02-25-2011 03:48 PM
AN fitting size
Going to a chart on the web, I see a 12 AN fitting has a inside dia of only 11/16. The oil tank breather hose on my car measures 1" inside dia. This is more than a 25% reduction in ID. I would like to find a can with at least a 1" connection. With the new breather assembly/turbo drip tank that am installing, the vent from the drip tank will not be hooked up further more eliminating yet another way for the oiling system to breath. Any input on this guys? Philip
Turbology 02-25-2011 05:28 PM
These are popular in the Subaru community...:)
Fast Motorsports: Aftermarket High Performance Car Parts and Accessories
http://fast-ms.com/products/FMS-ENG-100.jpg
http://fast-ms.com/products/FMS-ENG-150.jpg
A930Rocket 02-25-2011 06:19 PM
I held a tape measure to mine. The outside of the threads are ~15/16. The ID is ~12/16.
I can take a picture tomorrow.
mooney265 02-25-2011 06:24 PM
Yes, my mechanic also agrees with the 1" theory... without it, could cause pressure to build in crank case...
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
