Spring Cleaning!!!
I just got my intercooler back from being polished. What do you guy`s think???? Before and after. Next will be to powdercoat the fan.....
Tim 87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost.... Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims. |
What happened to your fan, it went from polished to dull? Always like shiny stuff in the engine bay! Looks good!
88' 930 03 Tacoma, 04 Duramax, 06 R350 Benz If you are traveling at the speed of light & turn on your headlights, does anything happen? |
The fan I polished by hand on the car then after I used cleaner on the engine it went back to that dull look. Should I have it polished or powdercoated red??????
Personally I would go for polish, & yours being older than an 86' shouldn't it have an aluminum fan & shroud? So the aluminum would hold the polish unlike magnesium.
Mine is an 87 so I assume it is magnesium. I love your island,one of my favorite`s.....
Tim 87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost.... Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims. Last edited by Tug68; 03-22-2010 at 03:19 PM.. |
Looks good. I'd go with a polished fan.
I polished my fan on a buffing wheel for hours. Looked good for awhile, but time took it's toll. Polished/silver powdercoat next time! |
They have a polished/silver in powdercoat? Is it bright or like a flat polish???
It looks good, but the fan being Mg will always go back to dull. Just polish it once in a while.
What if I got it powdercoated Miguel???
When you finally convince yourself that powdercoating is the only real option for keeping the fan looking good, make sure the guy doing the work tapes off the flat tips of the fan. Or else the tolerance build up between the tip of the fan blade and the housing will cause the fan to scratch and rub your new, pretty surface. And yes, they make a color of powdercoat that pretty much matches the look of polished magnesium.
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
Looking good!!
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
Ok, how hard is it to get the fan and fan shroud off????
Turbo Hooligan
I had my fan and housing powder coated, fan done in silver, and the housing done in a dull dark grey to resemble bare magnesium. best look i ever did. the bright color fans and housings don't age well IMO
D-Zug ![]() |
My fan came off pretty easy. I just removed the nut and wiggled the fan until the it pulled off. Others have had to use/make pullers etc to get theirs off.
The shroud is harder but not too bad. You need to remove the shroud clamp, coil, a few bolts on the cowling behind the fan. I then pull it out so I can get to the wires behind the alternator. Once those are removed I can pull the shroud out. Mine is at the powdercoaters right now. |
Thanks forwheeler post some pic`s when your done. I was quoted $300 to remove and reinstall the shroud and the fan, and another $200 to powdercoat them both. This might be the way to go.
I am getting my fan, shroud and the 4 valve covers coated for $75. It would be cheaper but I asked for 2 colors and extra masking work. I removed the parts myself. |
![]() Here is a pic of the parts after I received them from the powdercoaters. I was surprised at the amount of cleaning I needed to do to remove the blasting media from the uncoated side of the parts. I think they coated over some of the media on the fan shroud also but I didn't notice it until I got home. |
Looks good in the pic. can you have them do it over?I just found a local guy that has an extra fan and shroud that he will give me to get done and will swap them out when I get them to him. No down time but the 3 hr`s it will take to remove and reinstall....I`ll post pic`s here after I`m done....
Mine is magnesium - and I sanded it from 220 grit all the way to 1000 wet. Used a magnesium polishing compound and the sheen real even - then had it powder coated clear. Looks like polished aluminum
