930 turbo comperssor nut ??
Hello.
how many NM. compressor nut (17) must be tightened??
John
Old 05-08-2011, 10:33 AM
Manassas, VA
lucittm's Avatar
The correct torque depends on the strength of the material or the "Property Class" and I don't know the property class of the turbo shaft or the nut. However, reviewing the torque values for a M6x1mm thread, the Maryland Metrics table MARYLAND METRICS -- TORQUE VALUES CHART shows a value of 4.5 Nm for a class 4.6 fastener and a value of 23.8 Nm for a class 14.9 fastener.
Conservatively, I would think the shaft and nut of a K27 turbo would be equal to or exceed property class 8.8 and the maximum torque for that class is 12.1 Nm.
Of course you would have to rebalance the rotating assembly if it was disassembled. A turbo shop would probably have the correct torque specification.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 05-08-2011, 12:12 PM
mark houghton's Avatar
Mark
I did some research awhile back on turb rebuilding, and came up with two pieces of information as follows: Torque to 105 inch-pounds (right at about 12 Nm as Mark has already mentioned). I had also read somewhere to torque to 26 inch-pounds initially, then turn the nut an additional 90 degrees and call it good.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 05-09-2011, 10:01 AM
Roby466's Avatar
I am pretty sure that my turbo rebuilder told me 105 inch-pounds as well.
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 05-16-2011, 10:28 AM
Thanks for your help
regards John
Old 05-16-2011, 12:43 PM
