Ok Guys, got a dyno sheet
Well, the car is back on the road and it goes better
Below is the dyno sheet and for a refresher on my rebuild here is what we did to the motor in terms of improvements:SC cams FVD ignition advance mount Turbo Kraft porting to stock heads and intake 1.0 bar spring Billet diverter valve CarGraphic 100 cell cat Coated lower end bearings and piston skirts ARP bolts RUF oil cooler Turbo Kraft did a valve job too and a new clutch and flywheel. Stock P&C's I like it! Wished the boost came on a little sooner but that required more $, so for now I am satisfied. Without the help from all of you it would not have turned out this well so thanks everyone!
Steve 91 964 turbo 81 ROW 911SC 11 997.2 |
Banned
Very cool - bet that power feels great! I've followed your build from the start and glad to see it has come along so well !!!
R.I.P.
hmm, even with SC cams and ported heads you still have more torque than HP. I'm sure she's fun
Metal Guru
Steve, your still running the K27-7200 turbo?
What's the new diameter of the intake ports?
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I have now forgotten the intake and head porting size...I am guessing 38mm but I need to look at one of my earlier threads as I think I posted it.
