E-85 sippin drunk
turbobrat930's Avatar
oil cooler line AN size
Ok, I have searched these forums for a bit today, but all I could find was some fitting sizes for a 914 with a small 6 in it. What size AN fittings do I need to go from the stock hard lines in the car, to a nice aftermarket fender mount cooler? I was thinking -16. Has anyone gone larger? Do they need to be any larger, or is a -16 fine?
Because of my front bumper cap (GT-2), I will only be able to run a fender mounted cooler, which is fine.... If I need it, which, I doubt I will, I can have my ECU turn on a cooling fan on the cooler. (I have not bought the cooler yet, so thats why I need to know the correct AN fitting sizes).
FWIW, I have also eliminated the engine mounted oil cooler, and instead, have gone with the 993 factory style of a second oil filter in place of the oil cooler....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-10-2011, 11:37 AM
KS Roadrunner
koenig911's Avatar
You need female 30mm to male -16 AN adapter to fit on hard line. Check BAT for them.
Old 03-10-2011, 04:02 PM
proffighter's Avatar
Bought a kit from them, very nice, I can only recommend
Roland
930 Turbo '81 Too many modifications to list
Old 03-10-2011, 10:53 PM
