BAE Rev 3...it's not a BAE anymore
Well, after 2-1/2 years in the garage, I finally got the damn thing started today. The only BAE things left on the car are the rubberized bonnets, and some of the intake piping.
Countless mods in these past 2-1/2 years. The car started right up. 17 PSI on the WUR. I plugged the WUR in after about 5 minutes of run time, and control pressure went to 35 PSI, and the AFR gauge said 15+, so it was a bit lean. It has been filled with regular non-synthetic 5W-20 to run it in. Tomorrow I'll dump the oil and filter, put in the same oil to break in the rings a bit. Bad news: Leak at the oil line for the turbo feed, where the oil pressure switch is, so I have a lot of stuff to get out of the way to plug it, and reroute the line. Drain is not as good as I would like, so I may have to fabricate Catch Can Rev 2.0, and put a check valve at the 4th oil cooler...doesn't everyone have four oil coolers? Sounds good, however. It is now 3.0 SC, B-W T04B turbo, Flowmaster series 44 muffler, SC CIS with BL WUR, RPM Solenoid Switch. MSD 6AL with an MSD Boost Timing Master and a J&S Safeguard unit (not yet mounted, but the sensors are). JE custom 8.5:1 turbo special pistons and rings, final CR at 8.38:1. It will run at 5.8 PSI boost from a Tial 38 wastegate. OBX headers (I got them cheap, and figured I'd try em). Rest same as it was...ARP rod bolts, new oil pump, 993 Dilivar studs, DC-15 cams. We will see when I get it running AND driving. http://forums.pelicanparts.com/uploa...1301097801.jpg http://forums.pelicanparts.com/uploa...1301097821.jpg http://forums.pelicanparts.com/uploa...1301097941.jpg |
Patrick, you've got some unusual combinations of stuff on there. 2.5 years of anticipation, I bet you can hardly wait to put it in gear and hit the road. I bet she really kicks ass!
It kicked a$$ before with the old BAE turbo setup til I blew it up.
So, today, I pulled some stuff out of the way..AN-3 oil fitting was loose, which explains the oil pouring out over the gearbox. That was the best case scenario (my own stupidity). The old setup was putting out around 260+ RWHP. This setup should be over 300, I would imagine. SC's are fun with a lot of power. |
771 moved under its own power, out of the garage, and took a quick trip around the block. I needed it's space in the garage to troubleshoot the 968 anyway. Maybe this week we can work on making some boost.
http://forums.pelicanparts.com/uploa...1302960079.jpg |
Mark, thanks!
The guys at the track with the late models ask me "how are you keeping up with me in THAT?" |
Took the tub for a ride this evening. It sounds like a lawn mower. Ride wasn't long enough to get the oil warmed up, but I did get into 4th gear. I was going up the hill slowly near my house when I felt the boost come on at around 2500 RPM. I got on the flatland and it does make boost, but the recirc opens at about 2-3 PSI pounds, so the wastegate never opens...it is set at 5.8 PSI. It idles high, and I have to play with the WUR to get the cold and warm pressures dialed in. I think it has a vacuum leak somewhere. It was lugging at idle in gear. The fuel head is an old late model SC head I rebuilt, and tends to run a bit lean. I have an IA modded head, but that tended to run rich, and I haven't re-installed it since Stephen recalibrated it.
The tub has a few little issues, but it didn't blow up. It did get a little kick in it even at 2 PSI boost. I forgot what the rear engine was like. It is certainly not the 968 or the 986, which I have become adjusted to. |
The tub is more sorted now. I had no power to the WUR, so as soon as the car warmed up a little, it ran like crap. Got 12V power to the WUR, reset the warm control pressure to 3 bar, and took it for a spin.
The improvement in power and response is noticeable, even though I barely got the car warmed up. I got it making full (5.8PSI) boost, the water injection injected, and the boost pressure controller kicked in. It screamed through third gear. The B-W turbo is a big difference over the old Rajay. |
| All times are GMT -8. The time now is 12:35 PM. |
