-   -   Turbo Rebuild on 3LDZ that upgrades it to a K27, Anyone used this service? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/600517-turbo-rebuild-3ldz-upgrades-k27-anyone-used-service.html)
66cal912 04-01-2011 03:35 PM
Has any one used this service to upgrade a Stock 930 3LDZ turbo to a similar spec of a K27? I found this listing on Ebay offering the service and its definitely more cost friendly then slapping down the money for a K27-7200, given I am on a limited budget at this point? Any advice with this service or seller would be appreciated. The ad on Ebay looks pretty legit, and the turbo characteristic Chart, seems reasonable.
Please check it out:
Porsche 911 930 K27 3LDZ Fast Spool UPGRADED Turbo - eBay (item 170319204245 end time Apr-27-11 11:55:02 PDT)
thanks Ahead of Time! Ben
911TT33 04-01-2011 07:30 PM
Looks like a reasonably priced rebuild / upgrade.
Shoot them a message and ask what their warranty is?
Looks good to me though :cool:
Tug68 04-02-2011 07:49 AM
Tagging along, looks good.
RarlyL8 04-02-2011 08:06 AM
I use them for the 3LDZ rebuilds and upgrades we offer.
The stock rebuilds are nice for restorations and preservation cars while the modified 3LDZ is a good option for spec racers and enthusiasts who want a 100% plug and play turbo.
The characteristics of the modified 3LDZ move it toward those of a K27-7200. Design constraints of course do not allow replication of the 7200's map. I haven't put one on a dyno yet as it must be the only change taking place. Often there are other changes made at the same time, such as the muffler, which would skew the results.
oilonly 04-02-2011 01:46 PM
I purchased one from Brian and it absolutely spools up faster than my stock 3LDZ.
66cal912 04-03-2011 09:33 AM
Thanks!
Guys,
Thanks for the input. Much appreciated. Brian I was wondering if these were the same guys doin your rebuilds so thats good to know. If I go this way that definitely gives me confidence in going this route.
Ben
66cal912 04-03-2011 10:15 AM
Quick question, if I went with the high flow 3ldz turbo, would the stock intercooler and cis be adequate, or will I need additional fuel enrichment? Thx, Ben
oilonly 04-03-2011 03:59 PM
Don't know if it is needed but I also installed a larger long neck intercooler. I didn't change anything on my CIS system.
RarlyL8 04-03-2011 05:58 PM
No fueling mods are needed, however you should always verify your AFRs when making changes.
Stock intercooler is OK unless you are running more than stock boost, there should be no change in the heat load by adding this modified turbo for street use. In general bigger intercoolers are always a plus as anything that cools the intake charge is good.
Sam Matthews 04-03-2011 10:53 PM
3ldz
The first one I have purchased from Bruce leaked in the center but i resealed it and it works very well
p9eleven 10-11-2011 09:02 AM
3LDZm
How did you reseal it?
I have same issue that oil leaking from center (v-Band).
Thanks.
66cal912 11-18-2011 02:31 PM
Hello,
a few people emailed me on this topic some months back and I appoligize I have been so busy I never got back to you guys. I looked into the K26 rebuild / upgrade, but I decided to go with the 964 Turbo spec K27 KKK. Also this turbo as is will not fit the stock K26 brackets as most of you have or will find out. However there is an advantage of being in this business so long, and that is the fellows at Andial can help you out by machining the hot side turbo housing on a K27 to fit all the stock mount points / bracket and muffler if you desire. They still sell new in the box K27s and others if you need them. A little more then others, but the fact its drop in and their adapter is super cost affective, I would recomment them 100%, ask for Pete to help you, if you go this route.
Ben
