my 930 oil consumption
I have driven about 2400 miles since oil change.
I have added oil twice now. This makes it a total of 1 qt added since I changed the oil. The car leaks a little, but this probably doesn't account for much. The oil I use is Valvoline VR-1 20W-50 Is 1qt/2400 miles normal/acceptable? thanks
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Turbo Hooligan
So its burned off a quart? I think that is acceptable, I know my car will burn off roughly a quart after she gets filled up at oil change, but then she won't burn any more. If I leave the oil level just above the min mark on the dip stick it doesn't burn or use any oil, when I fill her up more (long trips, track days, etc,) she always burns off the oil till its back just above the min.
D-Zug ![]() |
I quart between oil changes @ 2K miles sounds good to me. I change oil around 2K( valvoline VR1 20w50) and usually on any of the 930 cars I have owned over the years do not have to add any to keep it above low/ under high when hot.
Anthony @ Voitureltd Bayside WI. |
Thank you guys.
I guess it's OK then. I bought VR-1 when it was on sale recently ![]() I hope to get time for an oil change next weekend.
A quart per 1500 miles is Ok, so thats 2 quarts usage per oil change, nothing to get excited about. That's even consistent with the owners manual.
Mines been consistent at this usage level for 3 years now, and I use mine as a daily driver. I bought my sled with 30K on the clock, now shows 77K. Mine does not drip or smoke. I run Kendall 20w-50w GT, 11 quarts pre oil change with a new filter. Mark |
oil change intervals
I usually change my oil once a year @ around 5,000 miles. Can you guys give me some in-site to why you would change the oil more frequently? Maybe the warmer climate you live in? Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo ![]() ![]() |
There's some evidence from oil analysis that changing oil too frequently increases wear (see the mondo oil thread). If, on the other hand, you drive the car hard, some of your oil is being pumped through the bearings on a turbo where the casting on the hot-side is glowing cherry red (that's what lights off the flame balls). So you should be using an oil that can take those temperatures - and change it frequently. I like heavy duty diesel oils for precisely those reasons - good additive package, and designed for that use. If you don't drive the car hard, remember the factory instructions to take the car full-throttle to red-line in at least one gear every time you drive it (think this is so the wastegate doesn't stick/rust).
'77 S with '78 930 power and a few other things. |
Mine doesn't leak a drop and doesn't appear to burn any either - but it does use oil. Much more so on short (15 mile) journeys as a DD, where a good fraction of the drive it is warming up. Hardly used any the last time I took it for a long run, didn't seem to use any at the track. I even had the leakdown checked at the last valve adjust - but all the figures were good. My oil level gauge agrees with my dipstick, so I just top up to halfway when it gets low and don't even bother keeping track.
Perfectly normal.
Why to change it so often? To save money. |
Thank you all for your inputs.
It seems that everything is normal. My 930 is a DD. I have not seen any signs of moisture on the oil cap. On another note: I have saved the sparkplugs from the two changes (changed plugs twice..., I know, that is a lot for 2400 miles, but I put autolites in after my flooding/no-start issues (some might remember). They were cheap and worked fine. After a while (when I did my injector flow testing) I changed to Bosch (expensive) and I am not sure I'd say they are worth the extra money. The plugs looked really nice when I changed them. I am keeping the next couple of sets. Just to be able to see if a discrepancy occurs. As a closing comment: I have bought new injectors. Once I get the time I'll install those. So far I am debating whether to send them in for testing prior to installation. I have heard even new ones do not necessarily flow the same. Once again, thank you for your feedback.
That said, the factory originally believed that they would make 250 930's for homologation - which they intended to sell to "friends of the factory" (and were worried about selling that many.) They thought these cars would probably spend most of their lives WOT on a track. So they spec'd plugs that were cold enough for that use (and were probably being cautious), and that's what they had when they were emission tested. It costs a lot for EPA testing, so 930's were never re-tested and they all used those plugs until much later - when they fitted a much hotter plug. Arguably, the plugs are way cold for town driving - but the stock Platinum plugs don't seem to foul. Ever. The Bosch Silver seem to work just as well, and they're much cheaper ($3-$4 each, IIRC).
